node-red-contrib-continuous 0.0.1
Node-RED node to do a continuous integration flow
npm install node-red-contrib-continuous
nodes for continuous integration with node-red
Use npm install node-red-contrib-continuous to install.
This package provides nodes to create a continuous integration flow.
The build node is used to build a project into a local directory and execute tests. The output contains the tests results in msg.payload.
The deploy node is used to to build a project into a local directory that is your deploy directory.
nodes
alt
build in action
alt
continuous integration sapmple
alt
Version: 0.0.1
Updated 1 year ago
0 in the last day
7 in the last week
34 in the last month
  • build
  • deploy
  • build
  • deploy
  • continuous
  • integration
  • mfou
