node-red-contrib-config 1.2.1
A node-red node to set flow and global context values at start up.
npm install node-red-contrib-config
A Node Red node for setting global and flow context properties at startup and during runtime.
This node allows you to store configuration information in a central location and use it to set global and flow context properties at startup (initialization phase) or during runtime. Multiple config nodes can be used to store alternate configuration settings and switch between them during runtime.
node-appearance
Fig. 1: Node appearance
In Node-RED
  • Via Manage Palette -> Search for "node-red-contrib-config"
In a shell
  • go to the Node-RED installation folder, e.g.: ~/.node-red
  • run npm install node-red-contrib-config
Node Configuration
node-settings
Fig. 2: Node properties
Configuration of Property and Value
The object given in the Property field is the context property which shall be modified. This object can be a global or a flow variable.
The contents of the Value field is the data which is written to the context property object. This object can be of the type
  • string
  • number
  • boolean
  • JSON
  • timestamp
Checkbox Active
If Active is checked (i.e. node is active), the configuration properties will be applied at startup before any flows are started. This may e.g. be used for initialization purposes.
Input
If the node receives any msg, it will apply the configuration properties contained in that config node. I.e. the value of the Value field is written into the variable given in the Property field. The received msg is discarded.
This allows e.g. to alter configurations programmatically.
Pressing the button on the left side of the node will also apply the configuration properties contained in that config node.
This allows also to alter configurations manually.
Output
The config node has no output data.
Example
Remark: Example flows are present in the examples subdirectory. In Node-RED they can be imported via the import function and then selecting Examples in the vertical tab menue.
The example flow shows an example where the global variable PC_Stability
  • is modified at startup (initial operation, only by the upper config node),
  • can be modified by the left button of both config nodes (manual operation),
  • can be modified by the upper both inject nodes (msg initiated operation).
The lower nodes only show the contents of the modified global variable.
ConfigNodeExampleFlow.json
Fig. 3: Config node example
The following figure shows the node configuration of the upper confignode.
Fig. 4: Example Config node properties
Version: 1.2.1
Updated 6 years, 5 months ago
Rating: 4.8 5
419 in the last week
  • config
  • config
