node-red-contrib-collectd 2.0.6
A Node-RED node to send metrics to Collectd.
npm install node-red-contrib-collectd
This node makes use of the Collectd plain text protocol provided by the unixsock
plugin. Simply enable the unixsock
plugin in your collectd.conf
LoadPlugin unixsock
<Plugin unixsock>
SocketFile "/var/run/collectd-unixsock"
SocketPerms "0666"
DeleteSocket true
</Plugin>
The SocketPerms
value ensures that any account on the system has write permissions to the socket file, but you can use SocketGroup
to restrict permissions to a specific group. Just be sure the account running Node-RED has permissions to write to the socket file!
This node can be connected to the output of any node, and will publish msg.payload
to a Collectd instance running on the local machine. It will use msg.timestamp
if set, otherwise the value N
will be sent to Collectd, which is interpreted as "now".
The button to the right of the node will toggle console logging of Collectd requests/replies on and off.
TODO
- Add support for sending data to a remote instance of Collectd
- Add support for native Collectd types
