node-red-contrib-circuit 2.1.1
node-red circuit extension
npm install node-red-contrib-circuit
This node-red-contrib-circuit is simple Node-Red git ui that allows you to easily integrate the functionality of the circuit sdk into your applications using node-red.
Pre-requisites
NodeRed NodeJS
Requires Node-Red version 0.18.7 or more recent.
Requires a https://circuitsandbox.net account with a bot to host the application with OAuth client_credentials.
Installations
Make sure you have NodeRed installed on your machine, if not you can install it by running the below command.
$ npm install -g --unsafe-perm node-red
Then you can start node-red by typing node-red in the command lind. More information on node-red can be found
at the node-red github here.
Installing node-red-contrib-circuit
Either install via pallette or via "npm install".
$ npm install node-red-contrib-circuit
Run the following command for global install.
$ npm install -g node-red-contrib-circuit
Getting started
  1. Install both node-red and node-red-contrib-circuit as displayed above.
  2. Once both packages are installed you will need a bot with OAuth client_credentials to run your application with.
    You can go here and follow the instructions to obtain your credentials.
  3. Start node-red by typing $ node-red into the command line and wait for the server to be loaded. After node-red is running you should be able to go to localhost:1880 to view your node-red server. If the node-red-contrib-circuit has been installed properly you should be able to scroll through your nodes and view the available API nodes to use.
  4. Once everything else is working you can follow the instructions in the Usage section.
  1. Select node with API functionality you desire.
  2. Enter the circuit-server information needed for bot, such as: client_id, client_secret, domain.
  3. Additional information on circuit client can be found at: https://github.com/circuit/circuit-sdk.
Applications
You can easily make applications using node-red and integrate them with our node-red-contrib-circuit API nodes. If you go here you can find an example flow that creates a bot to listen to a conversation and will send requests to look up weather, define words, and tell you jokes.
Testing
Under development...
Version: 2.1.1
21 in the last week
  • circuit-server
  • addParticipant
  • addTextItem
  • createConferenceBridge
  • createDirectConversation
  • createGroupConversation
  • Events
  • getConversationById
  • getConversationItems
  • getConversationParticipants
  • getConversations
  • getConversationsByIds
  • getDirectConversationWithUser
  • getItemById
  • getItemsById
  • getUserByEmail
  • getUserById
  • getUsersByEmail
  • getUsersById
  • setPresence
  • startUserSearch
  • updateConversation
  • updateTextItem
  • circuit
  • yourcircuit
  • unify
  • Roger Urscheler
