node-red-contrib-cayenne-mqtt-client 0.0.2
Cayenne MQTT Interface
This node allows you to hook up Node-RED to interface with Cayenne Bring Your Own Thing
In order to use this node you will require an account with Cayenne.
cd $HOME/.node-red
npm install node-red-contrib-cayenne-mqtt-client
Version History
0.0.2 - 2016-11-24
- All Cayenne Actuator Types now selectable in the dropdown list.
- All Cayenne Sensor Types now selectable in the dropdown list.
- The Nodes sends various logs to Node-REDs logging system. The logs are sent as
debug
. You must edit yoursettings.js
file in order to see them.
Note:
Only a (small) subset of the Actuators and Sensors are currently supported by Cayenne.
0.0.1 - 2016-11-19
Initial Version.
