node-red-contrib-canbus 1.0.1
A set of node-red nodes used for socketcan utilities
npm install node-red-contrib-canbus
A set of simple nodes for CANBus management on linux machines based on socketcan npm package(https://www.npmjs.com/package/socketcan, https://github.com/sebi2k1/node-can)
Current Status:-
  • canconfig to configure channel, bitrate
  • candump which listens for incoming frames and dumps id,dlc,data for each frame
  • cansend to send frame based on specfied id, payload or combination
  • Trying to implement similar functionality of socketcan utils like candump,cangen
  • Not using many options for cansend such as id range, frame count, duration in between as these are managed from input of additional function nodes
How to Enable Virtual CAN Channel:-
modprobe vcan
ip link add dev vcan0 type vcan
ip link set up vcan0
#you can refer https://github.com/linux-can/can-utils/
TODO/Wish List:-
  • Adding Support for extended frames
  • Adding more configuration values
  • Using better random engine
  • Integration with Kayak
  • Better documentation
Test flow:-
[{"id":"73a93f72.2489","type":"canconfig","z":0,"channel":"vcan0","bitrate":"100000"},{"id":"6e1ca89c.d417b","type":"cansend","z":"21e7592e.177786","config":"73a93f72.2489","canid":"","payload":"","x":570,"y":204,"wires":[]},{"id":"fa2cf7a7.55afe","type":"candump","z":"21e7592e.177786","name":"candump","vconfig":"73a93f72.2489","x":138,"y":104,"wires":[["f2631912.a5ca18"]]},{"id":"233b31e6.9f3d26","type":"inject","z":"21e7592e.177786","name":"","topic":"","payload":"200#abxy","payloadType":"string","repeat":"","crontab":"","once":false,"x":155,"y":203,"wires":[["7dc36d2.f427d14","fc78a840.c0006"]]},{"id":"f2631912.a5ca18","type":"debug","z":"21e7592e.177786","name":"","active":true,"console":"false","complete":"true","x":521,"y":108,"wires":[]},{"id":"3c5d3978.ef7fbe","type":"inject","z":"21e7592e.177786","name":"","topic":"","payload":"abcd","payloadType":"string","repeat":"","crontab":"","once":false,"x":149,"y":381,"wires":[["935e9142.7c2f9"]]},{"id":"935e9142.7c2f9","type":"function","z":"21e7592e.177786","name":"","func":"var msg;\nmsg.canid=129;\nreturn msg;","outputs":1,"noerr":0,"x":324,"y":384,"wires":[["7dc36d2.f427d14"]]},{"id":"1eb03187.f054de","type":"inject","z":"21e7592e.177786","name":"blank","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":false,"x":151,"y":288,"wires":[[]]},{"id":"7dc36d2.f427d14","type":"cansend","z":"21e7592e.177786","config":"73a93f72.2489","canid":"130","payload":"","x":575,"y":345,"wires":[]},{"id":"73fe1cf1.7d1bbc","type":"cansend","z":"21e7592e.177786","config":"73a93f72.2489","canid":"","payload":"hello","x":578,"y":274,"wires":[]},{"id":"fc78a840.c0006","type":"cansend","z":"21e7592e.177786","config":"73a93f72.2489","canid":"130","payload":"hello","x":581,"y":404,"wires":[]}]
Version: 1.0.1
Updated 10 years ago
Rating: 1.0 1
13 in the last week
  • cansend
  • candump
  • canconfig
  • socketcan
  • canbus
