node-red-contrib-calculate 0.1.4
A calculating node for node-red
Node-Red (http://nodered.org) nodes for some simple calculations over time or message count.
npm install node-red-contrib-calculate
Add the calculate node, select either a time period or a number of messages for release. Select calculation. Done.
Example
[{"id":"4c3a1551.6c254c","type":"random","z":"aff2cc18.0b484","name":"RandomNumber","low":"1","high":"100","inte":"true","property":"payload","x":340,"y":300,"wires":[["6f127280.30cf3c","6867669e.2a13a8","ac90cf81.6e61b","6dd3b70c.dfd938","596e1e94.3205b"]]},{"id":"6f127280.30cf3c","type":"calculate","z":"aff2cc18.0b484","name":"AvgEveryMinute","pauseType":"timed","calculation":"average","timeout":"1","timeoutUnits":"minutes","rate":"10","x":600,"y":180,"wires":[["4fb1838b.89fb2c"]]},{"id":"b32574cf.036708","type":"inject","z":"aff2cc18.0b484","name":"10SecBump","topic":"","payload":"","payloadType":"date","repeat":"10","crontab":"","once":true,"onceDelay":0.1,"x":140,"y":300,"wires":[["4c3a1551.6c254c"]]},{"id":"6867669e.2a13a8","type":"calculate","z":"aff2cc18.0b484","name":"AvgEvery10Msg","pauseType":"rate","calculation":"average","timeout":"10","timeoutUnits":"seconds","rate":"10","x":600,"y":240,"wires":[["4fb1838b.89fb2c"]]},{"id":"ac90cf81.6e61b","type":"calculate","z":"aff2cc18.0b484","name":"MedEveryMinute","pauseType":"timed","calculation":"median","timeout":"1","timeoutUnits":"minutes","rate":"10","x":610,"y":320,"wires":[["4fb1838b.89fb2c"]]},{"id":"6dd3b70c.dfd938","type":"calculate","z":"aff2cc18.0b484","name":"MinEveryMinute","pauseType":"timed","calculation":"min","timeout":"1","timeoutUnits":"minutes","rate":"10","x":600,"y":380,"wires":[["4fb1838b.89fb2c"]]},{"id":"596e1e94.3205b","type":"calculate","z":"aff2cc18.0b484","name":"MaxEveryMinute","pauseType":"timed","calculation":"max","timeout":"1","timeoutUnits":"minutes","rate":"10","x":610,"y":440,"wires":[["4fb1838b.89fb2c"]]},{"id":"4fb1838b.89fb2c","type":"debug","z":"aff2cc18.0b484","name":"Debug","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":870,"y":300,"wires":[]}]
Copy the json above, use Import Clipboard in the menu to add to your instance.
Disclaimer
Use at your own risk, of course, everything will be fine.
Author
Gustaf Ridderstolpe, https://github.com/obrut
Feedback and support
https://groups.google.com/forum/#!forum/node-red or specifically the subject https://groups.google.com/forum/#!topic/node-red/l8lVxeW6AGQ
