node-red-contrib-buspro 1.3.1
Node-Red implementation of HDL BusPro (SmartBus) protocol http://hdlautomation.com
Based on https://github.com/caligo-mentis/smart-bus.
BusPro-Controller
node that holds connection to IP Gateway of BusPro (Smart-Bus) network
Config
defaults: {
host: {value:"",required:true}, // HDL BusPro IP gateway
port: {value:6000, required:true, validate:RED.validators.number()}, // and port, default: 6000
subnetid: {value: 1, required: true, validate: RED.validators.number()}, // Connector address in HDL network (Subnet ID)
deviceid: {value: 99, required: true, validate: RED.validators.number()} // Connector address in HDL network (Device ID)
BusPro-IN
Receive commands from BusPro (Smart-Bus) network
Message format
msg:{
sender: "1.2", //ID of Sender Device
target: "255.255", //ID of Target Device
code: 50, //Integer with command operation code
payload: {}, //Object with decoded data or raw buffer if data can not be parsed automatically
topic: 'buspro/1.2/255.255/50' // topic contains a brief selection of parameters "buspro/{sender}/{target}/{command code}
Incoming messages can be filtered:
- All messages
- Broadcast only
- FROM specific device
- TO specific device
You can also use the filter by integer command code.
BusPro-OUT
Send commands to BusPro (Smart-Bus) network
Message for send to bus
msg:{
target: "1.52", //Target device address
code: 49, //Integer with command operation code
sender: "1.99", // (Optional) Source device address. A message will be sent from this device address. If the sender is not presented, it will be sent from the controller address
payload: { //Object with data or raw buffer
channel: 2,
level: 100
