node-red-contrib-buienradar 0.4.3
Current weather data from buienradar.nl
npm install node-red-contrib-buienradar
A Node-RED node that gets the weather from buienradar.nl.
Only one node with an input/output is available. More to come in near future. Only use this for personal use. This node depends on the data from buienradar.nl, for commercial use of their service please contact them directly. I am not related to buienradar.nl in any way.
Buienradar Node
Fetches the current weather for the selected weather station and polls it for the specified interval. Outputs a msg.payload.buienradar object which holds all the data.
Results
Current conditions will return
  • verwachtingMeerdaags - Forecast for upcoming days (detailed object)
  • verwachtingVandaag - Forecast for today (detailed object)
  • stationcode - unique station code which corresponds to a weather station
  • stationnaam - the weather station name
  • temperatuurGC - temperature in degrees celsius
  • windsnelheidBF - windspeed in beaufort
  • luchtvochtigheid - humidity in percentage
  • datum - the datetime of the measurement
  • zichtmeters - sight in meters
  • icoonactueel - an URL to the current weather icon
  • icoonzin - short description of the current weather
  • regenMMPU - rain in millimeters per hour
  • luchtdruk - air pressure
  • windrichtingGR - wind direction in degrees
  • windrichting - wind direction
  • zonintensiteitWM2 - sun intensity in watt per square meter
  • windsnelheidMS - wind speed in meters per second
  • windstotenMS - winds in meters per second
Weather data provided by Buienradar
Version: 0.4.3
Updated 4 years, 1 month ago
Rating: 5.0 2
37 in the last week
  • buienradar
  • weather
  • weer
  • buienradar
  • knmi
