node-red-contrib-bson 1.0.0
Node Red Node to create an ObjectID for mongodb.
Node-Red Node to create an ObjectID for queries in mongodb
Forking Note
I will publish this fork under the name of node-red-contrib-bson
until the contributors in node-red-contrib-objectid
treats message properly with RED.util.getMessageProperty
and RED.util.setMessageProperty
This small node-red node is used to create an ObjectID for mongodb.
The selected property in msg
will be converted to an ObjectID, you can input a 24 char hexstring and create an ObjectID from it.
For example: msg._id = "572dbc06f307c8682045c55c"
If the target property is null, a random id is created.
Deep reference
Deep reference is supported as a dot-separated string, e.g. payload._id
Array support
This module provides limited array support when the ending value is array.
For example, the following will work via this path "payload._id.$in"
payload: {
_id: {
$in: [
"5a8a92939034785a569ae7b8",
"5a8a92979034785a569ae7b9"
MIT: THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
