node-red-contrib-bravia 1.2.0
A Node-RED node to control Sony BRAVIA Android TVs.
This package contains nodes to control Sony BRAVIA Android TVs from Node-RED.
Setup
TV Setup
- Turn on your TV
- On the TV go to Settings > Network > Home network setup > Remote device/Renderer > On
- On the TV go to Settings > Network > Home network setup > IP Control > Authentication > Normal and Pre-Shared Key
- On the TV go to Settings > Network > Home network setup > Remote device/Renderer > Enter Pre-Shared Key > 0000 (or whatever you want your PSK Key to be)
- On the TV go to Settings > Network > Home network setup > Remote device/Renderer > Simple IP Control > On
Install with NPM
npm install node-red-contrib-bravia --save
There are 2 new nodes which appear in the category 'devices' in your Node-Red palette. Use the config node to set the hostname, port and PSK of your TV.
