node-red-contrib-brain2 0.1.8
Neural networks in Node-RED
npm install node-red-contrib-brain2
npm npm
$ cd $HOME/.node-red
$ npm install node-red-contrib-brain2
Or globally alongside Node-RED:
sudo npm install -g node-red-contrib-brain2
You will need to restart Node-RED for it to pick-up the new nodes.
node-red-contrib-brain2 is based on brain. You need to see it basic usage at first.
Import network
When there is msg.netJSON input, network wil be reloaded with JSON provided
Train
When brain node receive msg.trainData, it trains the network and output net.toJSON in msg.net. Additional network options can be provided in msg.neuralNetworkOptions. See brain options doc.
Run
When there is msg.runData input, brain node will run net.run() with data provided. And output the result in msg.decision.
Example
[{"id":"b3bd8bc0.b3a68","type":"debug","z":"7f66fc40.e319a4","name":"","active":true,"console":"false","complete":"decision","x":730,"y":440,"wires":[]},{"id":"28113a05.5a4d66","type":"inject","z":"7f66fc40.e319a4","name":"inject to run from network saved to flow","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":190,"y":440,"wires":[["d7867c2d.4a5ec"]]},{"id":"d7867c2d.4a5ec","type":"function","z":"7f66fc40.e319a4","name":"fake data","func":"msg.runData = { r: 1, g: 0.4, b: 0 }\nmsg.netJSON = flow.get(\"net\");\nreturn msg;","outputs":1,"noerr":0,"x":420,"y":440,"wires":[["6e3eac3e.09b554"]]},{"id":"ddac5726.90d5a","type":"debug","z":"7f66fc40.e319a4","name":"","active":true,"console":"false","complete":"net","x":720,"y":320,"wires":[]},{"id":"6eb2008.5eaa28","type":"inject","z":"7f66fc40.e319a4","name":"inject to train","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":270,"y":320,"wires":[["7d2cbf20.5940e8"]]},{"id":"7d2cbf20.5940e8","type":"function","z":"7f66fc40.e319a4","name":"fake data","func":"// This function return a fake json array\nmsg.trainData = [{input: { r: 0.03, g: 0.7, b: 0.5 }, output: { black: 1 }},\n           {input: { r: 0.16, g: 0.09, b: 0.2 }, output: { white: 1 }},\n           {input: { r: 0.5, g: 0.5, b: 1.0 }, output: { white: 1 }}]\n\nreturn msg;","outputs":1,"noerr":0,"x":420,"y":320,"wires":[["2eece628.29eab2"]]},{"id":"d1902d95.7145b","type":"function","z":"7f66fc40.e319a4","name":"save network to flow","func":"if (!!msg.net) flow.set(\"net\",msg.net);\nreturn msg;","outputs":1,"noerr":0,"x":780,"y":260,"wires":[[]]},{"id":"9858fd.1b8e7f","type":"inject","z":"7f66fc40.e319a4","name":"inject to run","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":270,"y":360,"wires":[["5b9f6fc3.1652e8"]]},{"id":"5b9f6fc3.1652e8","type":"template","z":"7f66fc40.e319a4","name":"runData","field":"runData","fieldType":"msg","format":"json","syntax":"plain","template":"{ r: 1, g: 0.4, b: 0 }","x":420,"y":360,"wires":[["2eece628.29eab2"]]},{"id":"2eece628.29eab2","type":"brain2","z":"7f66fc40.e319a4","name":"brain2","learningRate":0.3,"errorThresh":0.005,"iterations":20000,"log":false,"logPeriod":10,"x":570,"y":320,"wires":[["ddac5726.90d5a","d1902d95.7145b","b3bd8bc0.b3a68"]]},{"id":"6e3eac3e.09b554","type":"brain2","z":"7f66fc40.e319a4","name":"brain2","learningRate":0.3,"errorThresh":0.005,"iterations":20000,"log":false,"logPeriod":10,"x":570,"y":440,"wires":[["b3bd8bc0.b3a68"]]}]
MIT License
Version: 0.1.8
Updated 6 months, 1 week ago
3 in the last day
14 in the last week
45 in the last month
  • brain2
  • maxboar
