node-red-contrib-brain 0.1.4
Neural networks in Node-RED
npm install node-red-contrib-brain
npm npm
$ cd $HOME/.node-red
$ npm install node-red-contrib-brain
Or globally alongside Node-RED:
sudo npm install -g node-red-contrib-brain
You will need to restart Node-RED for it to pick-up the new nodes.
node-red-contrib-brain is based on brain. You need to see it basic usage at first.
Train
When there is no msg.netJSON input, brain node will train with msg.trainData and output net.toJSON in msg.net.
Run
When there is msg.netJSON input, brain node will not train anymore. Instead, it will directory run net.run() with your msg.runData. And output the result in msg.payload.
Options
You could pass a msg.neuralNetworkOptions to brain node. See brain options doc.
Example
Train:
[{"id":"d4a484b.f2b5b78","type":"debug","z":"46d50fa1.b92af","name":"","active":true,"console":"false","complete":"net","x":679,"y":175,"wires":[]},{"id":"3b4d60b3.c4b2a","type":"inject","z":"46d50fa1.b92af","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":150,"y":144,"wires":[["6d766489.92899c"]]},{"id":"6d766489.92899c","type":"function","z":"46d50fa1.b92af","name":"fake data","func":"// This function return a fake json array\nvar trainData = [{input: { r: 0.03, g: 0.7, b: 0.5 }, output: { black: 1 }},\n           {input: { r: 0.16, g: 0.09, b: 0.2 }, output: { white: 1 }},\n           {input: { r: 0.5, g: 0.5, b: 1.0 }, output: { white: 1 }}]\n\nmsg.trainData = trainData\nreturn msg;","outputs":1,"noerr":0,"x":333,"y":183,"wires":[["2fe2efbc.d01d1"]]},{"id":"2fe2efbc.d01d1","type":"brain","z":"46d50fa1.b92af","name":"brain","learningRate":0.3,"errorThresh":0.005,"iterations":20000,"log":false,"logPeriod":10,"x":516,"y":185,"wires":[["d4a484b.f2b5b78"]]}]
Run:
[{"id":"10d56f1d.ef2a91","type":"debug","z":"46d50fa1.b92af","name":"","active":true,"console":"false","complete":"payload","x":687,"y":346,"wires":[]},{"id":"808a1160.7f75f","type":"inject","z":"46d50fa1.b92af","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":131,"y":325,"wires":[["fbed5f0e.0412a"]]},{"id":"fbed5f0e.0412a","type":"function","z":"46d50fa1.b92af","name":"fake data","func":"// This function return a fake json array\nvar netJSON = {\"layers\":[{\"r\":{},\"g\":{},\"b\":{}},{\"0\":{\"bias\":0.5976173927716023,\"weights\":{\"r\":3.5006895738532835,\"g\":-4.542455700505483,\"b\":0.9988932386815509}},\"1\":{\"bias\":0.6470978455858952,\"weights\":{\"r\":3.6115725201557827,\"g\":-4.875546614413311,\"b\":1.211740813346471}},\"2\":{\"bias\":-0.3559477465736521,\"weights\":{\"r\":1.1063595019849224,\"g\":-1.857026678772011,\"b\":0.14886809335684345}}},{\"black\":{\"bias\":3.3336645409591017,\"weights\":{\"0\":-3.7876606581596914,\"1\":-4.023316483216229,\"2\":-1.0819957068479935}},\"white\":{\"bias\":-3.29149645757729,\"weights\":{\"0\":3.782751737648757,\"1\":4.173873416865656,\"2\":0.7154074171638515}}}],\"outputLookup\":true,\"inputLookup\":true}    \nvar runData = { r: 1, g: 0.4, b: 0 }\n\nmsg.runData = runData\nmsg.netJSON = netJSON\nreturn msg;","outputs":1,"noerr":0,"x":315,"y":336,"wires":[["3132e68b.cecd1a"]]},{"id":"3132e68b.cecd1a","type":"brain","z":"46d50fa1.b92af","name":"brain","learningRate":0.3,"errorThresh":0.005,"iterations":20000,"log":false,"logPeriod":10,"x":501,"y":341,"wires":[["10d56f1d.ef2a91"]]}]
MIT License
Version: 0.1.4
Updated 9 years, 1 month ago
  • brain
