node-red-contrib-botmaster 0.5.0
botmaster for node-red
npm install node-red-contrib-botmaster
Node-red nodes for Botmaster, the simple framework for serious chatbot projects.
Sample flow
Sample flow image
You can copy this flow below.
Supported Bots
  • Facebook Messenger
  • Slack
  • Twitter
  • Telegram
Middleware
Botmaster supports middleware, which can extend the functionality of your bot or make it easier to make a clever bot.
We've setup some middleware for you in the node-red edition of botmaster to make it easy!
Fulfill action tags
Fulfill utilises the concept of separation of concerns. You write an "action handler" once and using fulfill this action handler can be called anywhere from the bots output simply by putting an xml tag matching the name of the action handler.
For example the sample flow includes a <hi /> tag. This is used in a function node which greets the user when they write to the bot.
msg.payload = '<hi /> <pause wait=5000 /> How are you?'
The hi tag has a flow like the following.
Hi tag flow
The first function node simply sets msg.payload to "hi there", and returns the msg. The action end node then uses this payload to replace <hi /> in the message to the user with "hi there." The flow does not end there however, once this message containing hi has been sent the two nodes after the action end node retrieves a random giphy tagged with "Bot" from giphy.com and sends it to the user.
This leads to an experience like the following:
sample experience gif
Note that the pause tag splits the <hi /> into its own message and waits 5 seconds before sending how are you. So if it takes longer than 5 seconds to get the giphy the "how are you" will come before the giphy.
Read more about fulfill and also read the docs of the standard actions that are included.
When to use botmaster with Node-Red
Node-RED is a great way to get started with Node.js. Its also great for prototyping. However, if you want to take your bot into production you should probably consider using Botmaster without Node-RED. This will give you greater control and reliability and a more minimal stack. If you want to migrate from Node-RED, that's easy! There are several tutorials in plain Node.js at Botmasterai.com and all the functionality provided through the Botmaster nodes is also available though the vanilla packages.
Flow
You can use this flow to get started. Simply copy and use the menu option "import".
how to import
[{"id":"671b7971.aa9278","type":"function","z":"6b02241f.af3a2c","name":"say hello with actions","func":"msg.payload = '<hi /> <pause />How are you?'\nreturn msg;","outputs":1,"noerr":0,"x":720,"y":500,"wires":[["d8252620.cb9708"]]},{"id":"d8252620.cb9708","type":"bot response","z":"6b02241f.af3a2c","name":"","function":"reply","x":890,"y":500,"wires":[[]]},{"id":"54599219.f6a9cc","type":"action start","z":"6b02241f.af3a2c","name":"","tag":"hi","x":150,"y":680,"wires":[["d74a0b5b.5f38b8"]]},{"id":"fd25f621.c98cf8","type":"action end","z":"6b02241f.af3a2c","name":"","x":430,"y":680,"wires":[["7295d23f.818d4c"]]},{"id":"d74a0b5b.5f38b8","type":"function","z":"6b02241f.af3a2c","name":"hi there","func":"msg.payload = 'hi there';\nreturn msg;","outputs":1,"noerr":0,"x":278,"y":681,"wires":[["fd25f621.c98cf8"]]},{"id":"833d1c92.eb86b","type":"bot response","z":"6b02241f.af3a2c","name":"","function":"sendIsTypingMessageTo","x":350,"y":500,"wires":[["2f66929f.5c2dbe"]]},{"id":"2f66929f.5c2dbe","type":"delay","z":"6b02241f.af3a2c","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":540,"y":500,"wires":[["671b7971.aa9278"]]},{"id":"7f51c5b8.51456c","type":"function","z":"6b02241f.af3a2c","name":"hello actions","func":"msg.payload = '<hi /> <pause wait=5000 /> How are you?'\nreturn msg;","outputs":1,"noerr":0,"x":310,"y":300,"wires":[["7201701e.450db"]]},{"id":"7201701e.450db","type":"bot response","z":"6b02241f.af3a2c","name":"","function":"reply","x":450,"y":300,"wires":[[]]},{"id":"6e4878e7.1df408","type":"bot update","z":"6b02241f.af3a2c","name":"","x":170,"y":300,"wires":[["7f51c5b8.51456c"]]},{"id":"8f4c4c08.b008a","type":"bot update","z":"6b02241f.af3a2c","name":"","x":170,"y":500,"wires":[[]]},{"id":"99b3d30e.9973e","type":"watson-conversation-v1","z":"6b02241f.af3a2c","name":"","workspaceid":"","multiuser":true,"context":true,"x":430,"y":400,"wires":[["f9061c84.29dd1"]]},{"id":"e4f9bdbf.41cc6","type":"bot update","z":"6b02241f.af3a2c","name":"","x":170,"y":400,"wires":[[]]},{"id":"f507eb6a.745f18","type":"bot response","z":"6b02241f.af3a2c","name":"","function":"reply","x":690,"y":400,"wires":[[]]},{"id":"ab29bae2.53d5c8","type":"function","z":"6b02241f.af3a2c","name":"<->","func":"if (msg.update.message) {\n   msg.payload = msg.update.message.text;\n   msg.user = msg.update.sender.id;\n   return msg; \n}\n","outputs":1,"noerr":0,"x":290,"y":400,"wires":[["99b3d30e.9973e"]]},{"id":"f9061c84.29dd1","type":"function","z":"6b02241f.af3a2c","name":"<->","func":"msg.payload = msg.payload.output.text;\nreturn msg;","outputs":1,"noerr":0,"x":570,"y":400,"wires":[["f507eb6a.745f18"]]},{"id":"dac06b1c.9a3b78","type":"comment","z":"6b02241f.af3a2c","name":"Configure each bot","info":"","x":130,"y":60,"wires":[]},{"id":"e0a02d3b.7bb95","type":"comment","z":"6b02241f.af3a2c","name":"Handling updates","info":"","x":120,"y":200,"wires":[]},{"id":"fab7f834.454c38","type":"comment","z":"6b02241f.af3a2c","name":"Simple hello world","info":"","x":210,"y":260,"wires":[]},{"id":"43fe4a5e.733834","type":"comment","z":"6b02241f.af3a2c","name":"Using an NLU service","info":"","x":220,"y":360,"wires":[]},{"id":"8f68dde6.6f4d7","type":"comment","z":"6b02241f.af3a2c","name":"Chaining response tactics","info":"","x":230,"y":460,"wires":[]},{"id":"7e984d08.424714","type":"comment","z":"6b02241f.af3a2c","name":"Defining actions","info":"","x":100,"y":600,"wires":[]},{"id":"5d4767f4.f094d8","type":"function","z":"6b02241f.af3a2c","name":"sendUrl","func":"var imageUrl = msg.payload.data.image_url;\nmsg.params.bot.sendAttachmentFromURLTo(\n    \"image\",\n    imageUrl,\n    msg.params.update.sender.id, \n    {ignoreMiddleware:true}\n);\n/*msg.params.bot.sendAttachmentTo(\n    {\n        \"type\":\"image\",\n        \"payload\":{\n            \"url\": imageUrl\n        }\n    },\n    msg.params.update.sender.id, \n    {ignoreMiddleware:true}\n);*/\nreturn msg;","outputs":1,"noerr":0,"x":760,"y":680,"wires":[[]]},{"id":"7295d23f.818d4c","type":"http request","z":"6b02241f.af3a2c","name":"random giph","method":"GET","ret":"obj","url":"http://api.giphy.com/v1/gifs/random?api_key=dc6zaTOxFJmzC&tag=bot","tls":"","x":610,"y":680,"wires":[["5d4767f4.f094d8"]]},{"id":"9d42817a.9dfc6","type":"comment","z":"6b02241f.af3a2c","name":"giphy","info":"Here we retrive a random giphy image\n\nYou can read more about the api here\n\nhttps://github.com/Giphy/GiphyAPI#random-endpoint","x":590,"y":640,"wires":[]},{"id":"e0814abf.2084d8","type":"slackBot","z":"6b02241f.af3a2c","name":"","clientId":"","clientSecret":"","webhookEndpoint":"","x":380,"y":140,"wires":[]},{"id":"aba9fc12.2b6ff","type":"telegramBot","z":"6b02241f.af3a2c","name":"","authToken":"","webhookEndpoint":"","x":550,"y":140,"wires":[]},{"id":"372a5cb5.9d4c74","type":"twitterBot","z":"6b02241f.af3a2c","name":"","consumerKey":"","consumerSecret":"","accessToken":"","accessTokenSecret":"","x":700,"y":140,"wires":[]},{"id":"6c0129.2685bed8","type":"messengerBot","z":"6b02241f.af3a2c","name":"","verifyToken":"","pageToken":"","fbAppSecret":"","webhookEndpoint":"/","x":220,"y":140,"wires":[]}]
Version: 0.5.0
Updated 6 days ago
8 in the last day
181 in the last week
451 in the last month
  • action-start
  • action-end
  • bot-update
  • bot-response
  • messenger-bot
  • telegram-bot
  • slack-bot
  • twitter-bot
  • nodered
  • nodes
  • botmaster
  • botmaster
  • jwickens
