node-red-contrib-blynk-websockets 0.0.3
Node Red integration with Blynk App and Server through websockets
npm install node-red-contrib-blynk-websockets
Blynk app integration with Node Red using WebSockets protocol
Websockets version
This works for both local and cloud BLynk servers. For local, wss:// works if you ve got a certificate installed on BLynk server. FOr cloud Blynk server, only non ssl, ws:// works for the time being, as there is no SSL cert installed. You can use ws://cloud.blynk.cc:8082/ws as the server url.
NPM npm version
If you installed Node Red globally use this to install npm install --global node-red-contrib-blynk-websockets
Supports both SSL wss:// and non secured ws:// connection to local server.
Supported events and widgets
  • read event
  • write event
  • write command
  • emails
Blynk App Settings
Use Raspberry PI as hardware to access 64 virtual pins or Generic Board for 32.
How to use
TO ADD
Debug
TO ADD Use the verbose -v flag when starting Node-Red to get more information
Available Nodes
TO ADD
Version: 0.0.3
Updated 7 years, 5 months ago
5 in the last week
  • blynk-websockets-client
  • blynk-websockets-in-read
  • blynk-websockets-in-write
  • blynk-websockets-out-write
  • blynk-websockets-out-email
  • blynk
  • iot
  • websockets
