node-red-contrib-bluemix-hdfs 0.2.5
Big Data node on IBM Bluemix. This Node-RED node runs only in the IBM Bluemix environment
npm install node-red-contrib-bluemix-hdfs
bluemixhdfs
This is a Node-RED node meant for connecting to the Big Data on IBM Bluemix. This Node-RED node can be used only within the IBM Bluemix environment. This node requires a bound Analytics for Apache Hadoop service to work.
Within the Bluemix environment, the node specifically assumes that /user/biblumix as the home location.
Also, append the forward slash for any operation.
In case there is no bound Analytics for Apache Hadoop, then the node will warn about its inability to connect to the HDFS system and will not work.
Install from npm
HDFS Out Node
The HDFS Out node can be used to
  1. Create File
  2. Append to File and
  3. Delete File
HDFS In Out Node
The HDFS In Out node can be used to
  1. Read the file contents
Version: 0.2.5
Updated 11 years, 11 months ago
License: Apache
39 in the last week
  • ibm hdfs in
  • ibm hdfs
