node-red-contrib-bit 1.0.2
A Bit helper contribution package for Node-RED maintained by P4NR B2B Community.
npm install node-red-contrib-bit
Platform Node-RED Contribution Bit ES_Sourdce_Version ES_Deploy_Version NodeJS_Version Standard - JavaScript Style Guide NPM download NPM version Build and publish Gitpod Ready-to-Code
International IIoT Website for Node-RED
For an international area, Iniationware has provided the PLUS for Node-RED International website.
IIoT Webseite Deutschland für Node-RED
Für einen deutschsprachigen Bereich hat Iniationware die Webseite PLUS for Node-RED Germany bereitgestellt.
Contribution Information
Node-RED contribution package for Bit splitting
Run the following command for global install
npm install -g node-red-contrib-bit
try these options on npm install to build, if you have problems to install
--unsafe-perm --build-from-source
What is it?
Flow Example
Flow JSON
Debug
Debug will be activated by starting Node-RED with debug mode:
DEBUG=node_red_contrib_bit node-red -v
Authors
Klaus Landsdorf
Version: 1.0.2
Updated 1 month, 1 week ago
License: BSD-3-Clause
Rating: 5.0 2
87 in the last week
  • bit-simple-sixteen
  • bit-sixteen
  • bit-simple-thirtytwo
  • bit-thirtytwo
  • plusfornodered
  • converter
  • modbus
  • biancoroyal
