node-red-contrib-bigstatus 1.2.0
A Big Status node
Big "Status" node for node-red.
npm install node-red-contrib-bigstatus
Principles for Big Nodes
See biglib for details on Big Nodes.
Big Lib
and subsequent Big Nodes
are a family of nodes built for my own purpose. They are all designed to help me build a complete process for production purposes. For that I needed nodes able to:
- Flow big volume of data (memory control, work with buffers)
- Work with a flow of blocks (buffers) (multiple payload within a single job)
- Tell what they are doing with extended use of statuses (color/message)
- Use their second output for flow control (start/stop/running/status)
- Reuse messages in order to propagate _msgid, topic
- Depends on state of the art libraries for parsing (csv, xml, xlsxs, line, ...)
- Acts as filters by default (1 payload = 1 action) or data generators (block flow)
All functionnalities are built under a library named biglib
and all Big Nodes
rely on it
Usages
Big Status
is a debug node for Big Nodes. It acts as a filter for control messages and resend them as payloads suitable for debug
It works both ways:
- Connected to the second output of a Big Node, it shows visually the control data
- Controlled by messages, it can be used to show custom informations. It can be useful used with status node for triggering something elsewhere
This node has several properties
Locale
is used to compute durations in human form. You can tell which locale, the moment library will useShow duration
is used to add a computed duration base oncontrol start/stop/running
informations sent byBig Nodes
You can control the node by sending custom messages:
See Node Status node-red documentation page for details.
payload
ortext
is the text shown under the nodeshape
(ring
ordot
): if defined, draws an iconfill
(blue
,red
,yellow
,grey
orgreen
): the color for the icon. If none is set and shape defined, the color will beblack
Dependencies
moment Parse, validate, manipulate, and display dates in javascript
Example flow files
Try pasting in the flow file below that shows the node behaviour
[{"id":"85ae4fd9.7a51b","type":"bigstatus","z":"f14e3f02.0eb1c","name":"final status","locale":"fr","show_duration":true,"x":470,"y":1160,"wires":[[]]},{"id":"1c132ddd.e3ecd2","type":"inject","z":"f14e3f02.0eb1c","name":"manual","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":90,"y":1200,"wires":[["66f14cb0.990eb4"]]},{"id":"66f14cb0.990eb4","type":"function","z":"f14e3f02.0eb1c","name":"manual","func":"msg.control = { \"start\": msg.payload, \"end\": new Date(), \"state\": \"end\", \"message\": \"Le travail est fait en ... \" };\nreturn msg;","outputs":1,"noerr":0,"x":260,"y":1200,"wires":[["85ae4fd9.7a51b"]]},{"id":"29478e0f.d6b872","type":"inject","z":"f14e3f02.0eb1c","name":"reset","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":90,"y":1160,"wires":[["85ae4fd9.7a51b"]]},{"id":"52c20565.ad3dfc","type":"bigstatus","z":"f14e3f02.0eb1c","name":"","locale":"","x":470,"y":1440,"wires":[["c7867de3.38798"]]},{"id":"b2230bc0.4ddcf8","type":"inject","z":"f14e3f02.0eb1c","name":"ok!","topic":"","payload":"Everything if fine!","payloadType":"str","repeat":"","crontab":"","once":false,"x":90,"y":1280,"wires":[["33ced4cb.cc312c"]]},{"id":"33ced4cb.cc312c","type":"function","z":"f14e3f02.0eb1c","name":"green dot","func":"msg = { shape: \"dot\", fill: \"green\", text: msg.payload }\nreturn msg;","outputs":1,"noerr":0,"x":260,"y":1280,"wires":[["52c20565.ad3dfc"]]},{"id":"c7867de3.38798","type":"debug","z":"f14e3f02.0eb1c","name":"text","active":true,"console":"false","complete":"payload","x":630,"y":1440,"wires":[]},{"id":"6dd4ca24.922b34","type":"inject","z":"f14e3f02.0eb1c","name":"warn!","topic":"","payload":"Beware, this is a warning!","payloadType":"str","repeat":"","crontab":"","once":false,"x":90,"y":1400,"wires":[["5ffc6fc7.a0039"]]},{"id":"5ffc6fc7.a0039","type":"function","z":"f14e3f02.0eb1c","name":"yellow !","func":"msg = { shape: \"ring\", fill: \"yellow\", text: msg.payload }\nreturn msg;","outputs":1,"noerr":0,"x":260,"y":1400,"wires":[["52c20565.ad3dfc"]]},{"id":"447f3aa6.bb80c4","type":"inject","z":"f14e3f02.0eb1c","name":"error!","topic":"","payload":"Something went wrong, oh damn!","payloadType":"str","repeat":"","crontab":"","once":false,"x":90,"y":1340,"wires":[["42faad24.bd0554"]]},{"id":"42faad24.bd0554","type":"function","z":"f14e3f02.0eb1c","name":"red ring","func":"msg = { shape: \"ring\", fill: \"red\", text: msg.payload }\nreturn msg;","outputs":1,"noerr":0,"x":260,"y":1340,"wires":[["52c20565.ad3dfc"]]},{"id":"364464d9.c9bb9c","type":"inject","z":"f14e3f02.0eb1c","name":"blue!","topic":"","payload":"I'm blue!","payloadType":"str","repeat":"","crontab":"","once":false,"x":90,"y":1480,"wires":[["4dd3bd6f.b22c44"]]},{"id":"fba5ceac.045a3","type":"inject","z":"f14e3f02.0eb1c","name":"grey!","topic":"","payload":"I'm grey!","payloadType":"str","repeat":"","crontab":"","once":false,"x":90,"y":1540,"wires":[["67e5971c.981a68"]]},{"id":"4dd3bd6f.b22c44","type":"function","z":"f14e3f02.0eb1c","name":"blue ring","func":"msg = { shape: \"ring\", fill: \"blue\", text: msg.payload }\nreturn msg;","outputs":1,"noerr":0,"x":260,"y":1480,"wires":[["52c20565.ad3dfc"]]},{"id":"67e5971c.981a68","type":"function","z":"f14e3f02.0eb1c","name":"grey ring","func":"msg = { shape: \"ring\", fill: \"grey\", text: msg.payload }\nreturn msg;","outputs":1,"noerr":0,"x":260,"y":1540,"wires":[["52c20565.ad3dfc"]]},{"id":"57cf2558.a830dc","type":"comment","z":"f14e3f02.0eb1c","name":"Big Status sample","info":"","x":120,"y":1120,"wires":[]},{"id":"be20898b.41df78","type":"inject","z":"f14e3f02.0eb1c","name":"Black","topic":"","payload":"Black!","payloadType":"str","repeat":"","crontab":"","once":false,"x":90,"y":1600,"wires":[["931d9e22.6ce26"]]},{"id":"931d9e22.6ce26","type":"function","z":"f14e3f02.0eb1c","name":"grey ring","func":"msg = { shape: \"ring\", text: msg.payload }\nreturn msg;","outputs":1,"noerr":0,"x":260,"y":1600,"wires":[["52c20565.ad3dfc"]]}]
Another example using a Big Node
[{"id":"989581aa.676a8","type":"comment","z":"f14e3f02.0eb1c","name":"Status sample with Big Nodes","info":"","x":160,"y":860,"wires":[]},{"id":"62543d4d.9dabc4","type":"inject","z":"f14e3f02.0eb1c","name":"cron","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":110,"y":960,"wires":[["6212bdba.9ded44","54baa663.ab4558"]]},{"id":"6212bdba.9ded44","type":"moment","z":"f14e3f02.0eb1c","name":"last","topic":"","input":"payload","format":"fromNow","locale":"fr","output":"payload","x":270,"y":900,"wires":[["2ac993de.d5366c"]]},{"id":"2ac993de.d5366c","type":"bigstatus","z":"f14e3f02.0eb1c","name":"last run","locale":"","x":420,"y":900,"wires":[[]]},{"id":"f203749d.0dfc88","type":"bigstatus","z":"f14e3f02.0eb1c","name":"final status","locale":"","x":690,"y":1020,"wires":[["52cb0970.ad34f8"]]},{"id":"ef05ac63.10fa5","type":"status","z":"f14e3f02.0eb1c","name":"reset","scope":["4f77483e.b088b8","2ac993de.d5366c"],"x":530,"y":1060,"wires":[["f203749d.0dfc88"]]},{"id":"54baa663.ab4558","type":"bigexec","z":"f14e3f02.0eb1c","name":"Some job","command":"sh","commandArgs":"-c 'sleep 2; exit $(expr $(date +%s) % 2);'","minError":1,"minWarning":1,"cwd":"","shell":"","extraArgumentProperty":"","envProperty":"","format":"utf8","limiter":true,"payloadIs":"triggerNoStdin","x":280,"y":1020,"wires":[[],["f203749d.0dfc88"],[]]},{"id":"52cb0970.ad34f8","type":"debug","z":"f14e3f02.0eb1c","name":"","active":true,"console":"false","complete":"true","x":850,"y":1020,"wires":[]},{"id":"71872656.8e78d8","type":"comment","z":"f14e3f02.0eb1c","name":"Big Status is connected to the second output","info":"","x":530,"y":980,"wires":[]}]
Author
- Jacques W
This code is Open Source under an Apache 2 License.
You may not use this code except in compliance with the License. You may obtain an original copy of the License at
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. Please see the License for the specific language governing permissions and limitations under the License.
Feedback and Support
Please report any issues or suggestions via the Github Issues list for this repository.
For more information, feedback, or community support see the Node-Red Google groups forum at https://groups.google.com/forum/#!forum/node-red
