node-red-contrib-bigssh 1.2.9
A Big SSH
npm install node-red-contrib-bigssh
Principles for Big Nodes
See biglib for details on Big Nodes.
Big Lib
and subsequent Big Nodes
are a family of nodes built for my own purpose. They are all designed to help me build a complete process for production purposes. For that I needed nodes able to:
- Flow big volume of data (memory control, work with buffers)
- Work with a flow of blocks (buffers) (multiple payload within a single job)
- Tell what they are doing with extended use of statuses (color/message)
- Use their second output for flow control (start/stop/running/status)
- Reuse messages in order to propagate _msgid, topic
- Depends on state of the art libraries for parsing (csv, xml, xlsxs, line, ...)
- Acts as filters by default (1 payload = 1 action) or data generators (block flow)
All functionnalities are built into a library named biglib
and all Big Nodes
rely on it
Big SSH is an input node for node-red to execute command over ssh to a remote host Command can be set as a property of the node. Payload can be used to add arguments to the command and now, the command can be a javascript template string and payload the variables
You've first to set the authentication part which rely on a third party library. You've to test it as ssh always ask for some interactive answer at first try You'need then to set the command, choose how payload are used. Don't forget that you should give the full path of the command as environment is never set once connected on the remote
Dependencies
byline simple line-by-line stream reader
biglib library for building node-red flows that supports blocks, high volume
ssh2 third pary library for executing remote command using ssh
Example flow files
Try pasting in the flow file below that shows the node behaviour. Don't forget to set the credentials :-)
[{"id":"d3b7983c.c97908","type":"bigssh","z":"5f1eb5c5.4b8a5c","name":"","commandLine":"echo \"Welcome ${payload.me} to $(whoami)@$(hostname)\"","commandArgs":"","minError":1,"minWarning":1,"noStdin":false,"format":"","payloadIsArg":true,"myssh":"29df19bc.46db36","x":370,"y":200,"wires":[["477828b0.0ecb68"],["c3649904.a68108"],["743d5a09.a72bd4"]]},{"id":"c3649904.a68108","type":"bigstatus","z":"5f1eb5c5.4b8a5c","name":"","locale":"fr","show_date":true,"show_duration":false,"x":730,"y":200,"wires":[[]]},{"id":"477828b0.0ecb68","type":"bigline","z":"5f1eb5c5.4b8a5c","name":"","filename":"","format":"utf8","keepEmptyLines":false,"x":580,"y":140,"wires":[["614e8cdf.3d7ea4"],[]]},{"id":"614e8cdf.3d7ea4","type":"debug","z":"5f1eb5c5.4b8a5c","name":"stdout","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":710,"y":140,"wires":[]},{"id":"743d5a09.a72bd4","type":"bigline","z":"5f1eb5c5.4b8a5c","name":"","filename":"","format":"utf8","keepEmptyLines":false,"x":580,"y":260,"wires":[["33a59bcb.34ee64"],[]]},{"id":"33a59bcb.34ee64","type":"debug","z":"5f1eb5c5.4b8a5c","name":"stderr","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":710,"y":260,"wires":[]},{"id":"7a7fdea4.2ec13","type":"inject","z":"5f1eb5c5.4b8a5c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"me\":\"Mr J\"}","payloadType":"json","x":170,"y":200,"wires":[["d3b7983c.c97908"]]},{"id":"29df19bc.46db36","type":"SSH_Credentials","host":"127.0.0.1","port":"22","userlabel":"[email protected]"}]
Author
- Jacques W
This code is Open Source under an Apache 2 License.
You may not use this code except in compliance with the License. You may obtain an original copy of the License at
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. Please see the License for the specific language governing permissions and limitations under the License.
Feedback and Support
Please report any issues or suggestions via the Github Issues list for this repository.
For more information, feedback, or community support see the Node-Red Google groups forum at https://groups.google.com/forum/#!forum/node-red
Releases
1.2.9 - 2021/08/03
With "msg.config.uhcred" set on its input, the node will look for this credential configuration and change to it if found. This is related to issue #30
