node-red-contrib-bigline 1.2.0
A Big Line feeder
npm install node-red-contrib-bigline
"Line" parser for Big Nodes. Following the "big csv" and "big file" implementations, here is a node working the same way
alt tag
alt tag
Principles for Big Nodes
See biglib for details on Big Nodes. Big Lib and subsequent Big Nodes are a family of nodes built for my own purpose. They are all designed to help me build a complete process for production purposes. For that I needed nodes able to:
  • Flow big volume of data (memory control, work with buffers)
  • Work with a flow of blocks (buffers) (multiple payload within a single job)
  • Tell what they are doing with extended use of statuses (color/message)
  • Use their second output for flow control (start/stop/running/status)
  • Reuse messages in order to propagate _msgid, topic
  • Depends on state of the art libraries for parsing (csv, xml, xlsxs, line, ...)
  • Acts as filters by default (1 payload = 1 action) or data generators (block flow)
All functionnalities are built under a library named biglib and all Big Nodes rely on it
Usages
Big Line is a filter node for node-red to transform data into lines, one message per line. It uses the "byline" library
It works as a filter node that means it takes in the output of a "big file" node or any block node. It's able to read a file by itself to send lines
It has two options as byline offers them:
  • data format (utf8, latin, hexdec, base64, ucs2 and ascii). This option is only used when reading a file
  • keep empty lines
It has a filename property used to read files in the specific given data format*
Dependencies
byline simple line-by-line stream reader
biglib library for building node-red flows that supports blocks, high volume
Example flow files
Try pasting in the flow file below that shows the node behaviour
[{"id":"7f677e4c.80988","type":"inject","z":"d7f0f148.280f1","name":"GO","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":430,"y":120,"wires":[["23aa1547.dc55ea"]]},{"id":"23aa1547.dc55ea","type":"function","z":"d7f0f148.280f1","name":"sample data","func":"msg.control = { state: \"standalone\" }\nmsg.payload = \"This is a line\\nThis is a second line\\n\\nThis is a ending line\"\nreturn msg;","outputs":1,"noerr":0,"x":610,"y":200,"wires":[["f219f15e.0de61"]]},{"id":"f219f15e.0de61","type":"bigline","z":"d7f0f148.280f1","name":"big line","filename":"","format":"utf8","keepEmptyLines":true,"x":800,"y":280,"wires":[["e68deb8e.197218"],["e1300565.1ecff8"]]},{"id":"e68deb8e.197218","type":"debug","z":"d7f0f148.280f1","name":"lines","active":true,"console":"false","complete":"payload","x":970,"y":200,"wires":[]},{"id":"e1300565.1ecff8","type":"debug","z":"d7f0f148.280f1","name":"status","active":true,"console":"false","complete":"control","x":970,"y":340,"wires":[]},{"id":"220d8b4e.ddf274","type":"inject","z":"d7f0f148.280f1","name":"GO keep empty lines","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":140,"y":220,"wires":[["d72e181d.28d1e8"]]},{"id":"6d8a0609.9275f8","type":"inject","z":"d7f0f148.280f1","name":"GO ignore empty lines","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":140,"y":300,"wires":[["d6aad846.295528"]]},{"id":"d6aad846.295528","type":"function","z":"d7f0f148.280f1","name":"keepEmptyLines=false","func":"msg.config = { keepEmptyLines: false }\nreturn msg;","outputs":1,"noerr":0,"x":380,"y":280,"wires":[["23aa1547.dc55ea"]]},{"id":"d72e181d.28d1e8","type":"function","z":"d7f0f148.280f1","name":"keepEmptyLines=true","func":"msg.config = { keepEmptyLines: true }\nreturn msg;","outputs":1,"noerr":0,"x":380,"y":200,"wires":[["23aa1547.dc55ea"]]},{"id":"44d2ade5.bb2d54","type":"comment","z":"d7f0f148.280f1","name":"This node accepts on the fly configuration","info":"","x":189,"y":150,"wires":[]},{"id":"396f3087.c690d","type":"comment","z":"d7f0f148.280f1","name":"4 lines of data with 1 empty line","info":"","x":690,"y":160,"wires":[]},{"id":"1aa13977.e55ec7","type":"comment","z":"d7f0f148.280f1","name":"control messages (start, stop, ...)","info":"","x":1050,"y":380,"wires":[]},{"id":"86fb9d2f.79046","type":"comment","z":"d7f0f148.280f1","name":"One message per line","info":"","x":1020,"y":240,"wires":[]},{"id":"a92d08b1.56d2f8","type":"comment","z":"d7f0f148.280f1","name":"Simple trigger","info":"","x":450,"y":80,"wires":[]},{"id":"24787944.db8786","type":"inject","z":"d7f0f148.280f1","name":"GO with an error","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":120,"y":360,"wires":[["aa1b01cb.55e5"]]},{"id":"aa1b01cb.55e5","type":"function","z":"d7f0f148.280f1","name":"Non existing file","func":"msg.filename = \"/A/Probably/Non/Existing/File\"\nreturn msg;","outputs":1,"noerr":0,"x":600,"y":360,"wires":[["f219f15e.0de61"]]},{"id":"83a230ab.7c5dd","type":"comment","z":"d7f0f148.280f1","name":"Big Line sample usage","info":"","x":120,"y":40,"wires":[]}]
alt tag
Author
  • Jacques W
This code is Open Source under an Apache 2 License.
You may not use this code except in compliance with the License. You may obtain an original copy of the License at
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. Please see the License for the specific language governing permissions and limitations under the License.
Feedback and Support
Please report any issues or suggestions via the Github Issues list for this repository.
For more information, feedback, or community support see the Node-Red Google groups forum at https://groups.google.com/forum/#!forum/node-red
Version: 1.2.0
Updated 8 years, 7 months ago
8 in the last week
  • bigline
