node-red-contrib-bigfixed 1.0.1
A Big Fixed-data parser
"Big Fixed" is a Big Node for node-red. It's used to parse fixed length data
npm install node-red-contrib-bigfixed
Principles for Big Nodes
See biglib for details on Big Nodes.
Big Lib
and subsequent Big Nodes
are a family of nodes built for my own purpose. They are all designed to help me build a complete process for production purposes. For that I needed nodes able to:
- Flow big volume of data (memory control, work with buffers)
- Work with a flow of blocks (buffers) (multiple payload within a single job)
- Tell what they are doing with extended use of statuses (color/message)
- Use their second output for flow control (start/stop/running/status)
- Reuse messages in order to propagate _msgid, topic
- Depends on state of the art libraries for parsing (csv, xml, xlsxs, line, ...)
- Acts as filters by default (1 payload = 1 action) or data generators (block flow)
All functionnalities are built under a library named biglib
and all Big Nodes
rely on it
Dependencies
biglib library for building node-red flows that supports blocks, high volume
Capabilities
- This node's purpose is to parse fixed length data. Description is provided by configuration or the msg.description property.
This node has 3 properties:
- A data format, required, used to parse incoming data. The format is an array of json document
- A Trim each value flag used to trim spaces from each element of each line
- A Silently ignore non matching flag which allows non matching data without throwning errors
It is possible to send these configuration options using an incoming message setting respectively msg.description
, msg.trim
and msg.ignore
Format is a JSON array for column description.
- Each column is described by either a start, length, end value (all starting by 1). Different combinations are allowed as only start or start + length or start + end
- A header which is the property name. If no header is provided, the value is bound to a default named property Col # (Col1, Col2, ...)
- The trim flag is allowed for each column description or as a global parameter
- It's also possible to give a map translation table as for example
json "map": { "O": true, "N": false }
Example flow files
Try pasting in the flow file below that shows the node behaviour
[{"id":"123e3061.edc1d","type":"inject","z":"de6fd7b8.219028","name":"Sample","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":130,"y":120,"wires":[["7d6e179.f8291e8"]]},{"id":"7d6e179.f8291e8","type":"function","z":"de6fd7b8.219028","name":"Sample","func":"msg.payload = \"DATA1 DADA2 DATA3 \";\nreturn msg;","outputs":1,"noerr":0,"x":280,"y":120,"wires":[["e6f9a5eb.190658"]]},{"id":"e6f9a5eb.190658","type":"bigfixed","z":"de6fd7b8.219028","name":"fixed","trim":false,"syntax":"javascript","description":"[\n { \"start\": 1, \"length\": 10, \"trim\": true, \"header\": \"H1\" },\n { \"start\": 13, \"length\": 3, \"header\": \"D2\" },\n { \"header\": \"LAST\", \"trim\": true }\n]","ignore":true,"x":430,"y":120,"wires":[["5725bc93.a8da44"],["2087e47b.df781c"]]},{"id":"5725bc93.a8da44","type":"debug","z":"de6fd7b8.219028","name":"data","active":true,"console":"false","complete":"payload","x":690,"y":100,"wires":[]},{"id":"cf7165e3.308e98","type":"comment","z":"de6fd7b8.219028","name":"Sample usage of Big Fixed","info":"","x":190,"y":60,"wires":[]},{"id":"2087e47b.df781c","type":"function","z":"de6fd7b8.219028","name":"records","func":"if (msg.control && msg.control.state == 'end') return { payload: msg.control.records }","outputs":1,"noerr":0,"x":700,"y":140,"wires":[["1d141fec.e2ebe"]]},{"id":"1d141fec.e2ebe","type":"debug","z":"de6fd7b8.219028","name":"records","active":true,"console":"false","complete":"payload","x":840,"y":140,"wires":[]},{"id":"ff8b58af.0074a8","type":"inject","z":"de6fd7b8.219028","name":"Sample","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":130,"y":180,"wires":[["d7b9e1c9.28462"]]},{"id":"d7b9e1c9.28462","type":"function","z":"de6fd7b8.219028","name":"Error","func":"msg.payload = \"DATA1\";\nmsg.description = [\n { \"start\": 1, \"length\": 10, \"trim\": true, \"header\": \"H1\" },\n { \"start\": 13, \"length\": 3, \"header\": \"D2\" },\n { \"header\": \"LAST\", \"trim\": true }\n]\nreturn msg;","outputs":1,"noerr":0,"x":270,"y":180,"wires":[["8dcbdd77.72342"]]},{"id":"8dcbdd77.72342","type":"bigfixed","z":"de6fd7b8.219028","name":"fixed","trim":false,"syntax":"javascript","description":"","ignore":false,"x":430,"y":180,"wires":[[],[]]},{"id":"aa93452c.556cb8","type":"inject","z":"de6fd7b8.219028","name":"Sample","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":130,"y":240,"wires":[["a42c9bfa.5bd368"]]},{"id":"a42c9bfa.5bd368","type":"function","z":"de6fd7b8.219028","name":"Ignore","func":"msg.payload = \"DATA1\";\nmsg.description = [\n { \"start\": 1, \"length\": 10, \"trim\": true, \"header\": \"H1\" },\n { \"start\": 13, \"length\": 3, \"header\": \"D2\" },\n { \"header\": \"LAST\", \"trim\": true }\n]\nmsg.ignore = true;\nreturn msg;","outputs":1,"noerr":0,"x":270,"y":240,"wires":[["c1d5c08f.3e2a4"]]},{"id":"c1d5c08f.3e2a4","type":"bigfixed","z":"de6fd7b8.219028","name":"fixed","trim":false,"syntax":"javascript","description":"","ignore":false,"x":430,"y":240,"wires":[[],[]]}]
Author
- Jacques W
This code is Open Source under an Apache 2 License.
You may not use this code except in compliance with the License. You may obtain an original copy of the License at
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. Please see the License for the specific language governing permissions and limitations under the License.
Feedback and Support
Please report any issues or suggestions via the Github Issues list for this repository.
For more information, feedback, or community support see the Node-Red Google groups forum at https://groups.google.com/forum/#!forum/node-red
