node-red-contrib-bigexec 1.3.3
A Big Exec
npm install node-red-contrib-bigexec
"Big Exec" is a Big Node for node-red. It's used to execute command
alt tag
alt tag
Principles for Big Nodes
See biglib for details on Big Nodes. Big Lib and subsequent Big Nodes are a family of nodes built for my own purpose. They are all designed to help me build a complete process for production purposes. For that I needed nodes able to:
  • Flow big volume of data (memory control, work with buffers)
  • Work with a flow of blocks (buffers) (multiple payload within a single job)
  • Tell what they are doing with extended use of statuses (color/message)
  • Use their second output for flow control (start/stop/running/status)
  • Reuse messages in order to propagate _msgid, topic
  • Depends on state of the art libraries for parsing (csv, xml, xlsxs, line, ...)
  • Acts as filters by default (1 payload = 1 action) or data generators (block flow)
All functionnalities are built under a library named biglib and all Big Nodes rely on it
Dependencies
biglib library for building node-red flows that supports blocks, high volume node-shell-quote quote and parse shell commands event-stream EventStream is like functional programming meets IO mustache to upgrade environment variables with templates
Capabilities
This now launches a command using spawn which gives 3 streams, 1 for stdin, 1 for stdout and 1 for stderr. This node can launch command which doesn't need any input or a single message as an input or a flow of messages if driven by a Big Node (with control messages)
  • It's possible to use payload as extra arguments to the command
  • It's possible to use another message property for extra arguments (in cas payload is stdin and the extra property means extra parameters)
  • It's possible to set minimum error codes in order to get a warning or error status for the node
  • It's possible to set extra environment variables in mustache form to complete existing one (example: { PATH: "{{PATH}}:." })
  • It's possible to tell which encoding is used for stdout for example, if the result of a command is in binary form to translate it to utf-8
Example flow files
Try pasting in the flow file below that shows the node behaviour
[{"id":"d5de2d26.2a21d","type":"bigexec","z":"f29bfab4.0d6408","name":"","command":"sh","commandArgs":"-c '(echo stdout; echo stderr >&2)'","minError":1,"minWarning":1,"cwd":"","shell":false,"extraArgumentProperty":"","envProperty":"","x":760,"y":300,"wires":[["5fc11ed1.a03ee"],["ea429413.15bd68"],["264e6051.d9b1a"]]},{"id":"f8c5aa9.f073a58","type":"debug","z":"f29bfab4.0d6408","name":"output","active":true,"console":"false","complete":"payload","x":570,"y":500,"wires":[]},{"id":"fe42cda2.01bd3","type":"bigexec","z":"f29bfab4.0d6408","name":"true","command":"true","commandArgs":"","minError":1,"minWarning":"","cwd":"","shell":false,"x":270,"y":100,"wires":[[],[],[]]},{"id":"9984f682.667b08","type":"bigexec","z":"f29bfab4.0d6408","name":"sh","command":"sh","commandArgs":"-c","minError":"8","minWarning":"1","cwd":"/tmp","shell":false,"extraArgumentProperty":"","envProperty":"","format":"utf8","payloadIs":"argument","x":710,"y":140,"wires":[[],[],[]]},{"id":"2bb9bf06.d4464","type":"inject","z":"f29bfab4.0d6408","name":"","topic":"","payload":"\"exit 0\"","payloadType":"str","repeat":"","crontab":"","once":false,"x":550,"y":100,"wires":[["9984f682.667b08"]]},{"id":"89ba4484.7645b8","type":"inject","z":"f29bfab4.0d6408","name":"","topic":"","payload":"\"exit 1\"","payloadType":"str","repeat":"","crontab":"","once":false,"x":550,"y":140,"wires":[["9984f682.667b08"]]},{"id":"15f3c5e6.ea0c3a","type":"inject","z":"f29bfab4.0d6408","name":"","topic":"","payload":"\"exit 8\"","payloadType":"str","repeat":"","crontab":"","once":false,"x":550,"y":180,"wires":[["9984f682.667b08"]]},{"id":"64eb1fc.f9b14e","type":"bigexec","z":"f29bfab4.0d6408","name":"sleep","command":"sleep","commandArgs":"","minError":"8","minWarning":"1","cwd":"/tmp","shell":true,"extraArgumentProperty":"","envProperty":"","x":270,"y":380,"wires":[[],[],[]]},{"id":"f8e2ffe.f071d","type":"inject","z":"f29bfab4.0d6408","name":"","topic":"","payload":"10","payloadType":"num","repeat":"","crontab":"","once":false,"x":110,"y":380,"wires":[["64eb1fc.f9b14e"]]},{"id":"84c0f395.7b3f1","type":"inject","z":"f29bfab4.0d6408","name":"True!","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":110,"y":100,"wires":[["fe42cda2.01bd3"]]},{"id":"8ec7d32f.71383","type":"bigexec","z":"f29bfab4.0d6408","name":"false","command":"false","commandArgs":"","minError":1,"minWarning":"","cwd":"","shell":false,"extraArgumentProperty":"","envProperty":"","x":270,"y":180,"wires":[[],[],[]]},{"id":"e80797ae.17f868","type":"inject","z":"f29bfab4.0d6408","name":"False!","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":110,"y":180,"wires":[["8ec7d32f.71383"]]},{"id":"c4498d7f.3bb67","type":"inject","z":"f29bfab4.0d6408","name":"Hello!","topic":"","payload":"Hello you!","payloadType":"str","repeat":"","crontab":"","once":false,"x":110,"y":500,"wires":[["8d33cea7.72cc3"]]},{"id":"8d33cea7.72cc3","type":"bigexec","z":"f29bfab4.0d6408","name":"echo","command":"echo","commandArgs":"","minError":1,"minWarning":"","cwd":"","shell":false,"extraArgumentProperty":"","envProperty":"","format":"utf8","payloadIs":"argument","x":270,"y":500,"wires":[["d3ea0250.2c16"],[],[]]},{"id":"d3ea0250.2c16","type":"function","z":"f29bfab4.0d6408","name":"toString()","func":"msg.payload = msg.payload.toString()\nreturn msg;","outputs":1,"noerr":0,"x":420,"y":500,"wires":[["f8c5aa9.f073a58"]]},{"id":"31646763.ce9b98","type":"bigexec","z":"f29bfab4.0d6408","name":"unknown","command":"/I/m/not/existing","commandArgs":"","minError":1,"minWarning":1,"cwd":"","shell":"","extraArgumentProperty":"","envProperty":"","x":280,"y":300,"wires":[[],[],[]]},{"id":"cb4518e9.34bae8","type":"inject","z":"f29bfab4.0d6408","name":"unknown","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":120,"y":300,"wires":[["31646763.ce9b98"]]},{"id":"6f6db996.909248","type":"debug","z":"f29bfab4.0d6408","name":"stdout","active":true,"console":"false","complete":"payload","x":1110,"y":240,"wires":[]},{"id":"d12de8f8.2ed218","type":"debug","z":"f29bfab4.0d6408","name":"stderr","active":true,"console":"false","complete":"payload","x":1110,"y":360,"wires":[]},{"id":"4dfd7668.b20288","type":"inject","z":"f29bfab4.0d6408","name":"sample echo","topic":"","payload":"3","payloadType":"num","repeat":"","crontab":"","once":false,"x":570,"y":300,"wires":[["d5de2d26.2a21d"]]},{"id":"ea429413.15bd68","type":"function","z":"f29bfab4.0d6408","name":"rc","func":"if (msg.control && (msg.control.state == 'end' || msg.control.state == 'error')) return { payload: msg.control.rc }","outputs":1,"noerr":0,"x":950,"y":300,"wires":[["c9d0ae96.362f5"]]},{"id":"c9d0ae96.362f5","type":"debug","z":"f29bfab4.0d6408","name":"rc","active":true,"console":"false","complete":"payload","x":1110,"y":300,"wires":[]},{"id":"d7d24f0d.282db","type":"comment","z":"f29bfab4.0d6408","name":"Sample usage of Big Exec (Linux / Mac) command lines","info":"","x":240,"y":40,"wires":[]},{"id":"5fc11ed1.a03ee","type":"function","z":"f29bfab4.0d6408","name":"toString()","func":"msg.payload = msg.payload.toString()\nreturn msg;","outputs":1,"noerr":0,"x":960,"y":240,"wires":[["6f6db996.909248"]]},{"id":"264e6051.d9b1a","type":"function","z":"f29bfab4.0d6408","name":"toString()","func":"msg.payload = msg.payload.toString()\nreturn msg;","outputs":1,"noerr":0,"x":960,"y":360,"wires":[["d12de8f8.2ed218"]]},{"id":"e3dc229b.1c23e","type":"comment","z":"f29bfab4.0d6408","name":"Big Line should be better here","info":"","x":1020,"y":180,"wires":[]},{"id":"1b1197e8.e4ee68","type":"comment","z":"f29bfab4.0d6408","name":"Showing 3 states statuses","info":"","x":770,"y":80,"wires":[]},{"id":"85fee1ad.7a012","type":"comment","z":"f29bfab4.0d6408","name":"Sending data through stdin","info":"","x":330,"y":460,"wires":[]},{"id":"e9635a5.f169ca8","type":"comment","z":"f29bfab4.0d6408","name":"Unknow command","info":"","x":310,"y":260,"wires":[]}]
alt tag
Author
  • Jacques W
This code is Open Source under an Apache 2 License.
You may not use this code except in compliance with the License. You may obtain an original copy of the License at
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. Please see the License for the specific language governing permissions and limitations under the License.
Feedback and Support
Please report any issues or suggestions via the Github Issues list for this repository.
For more information, feedback, or community support see the Node-Red Google groups forum at https://groups.google.com/forum/#!forum/node-red
Version: 1.3.3
Updated 3 years, 3 months ago
15 in the last week
  • bigexec
