node-red-contrib-betterplus-sftp 1.0.0
A betterplus node for SFTP communication.
npm install node-red-contrib-betterplus-sftp
This is a fork of node-red-contrib-better-sftp
Betterplus SFTP was created out of necessity for a SFTP node which was fully implemented and had several options to configure algorithms (and "somewhat" up-to-date dependencies).
Big shout out to jyu213 for creating ssh2-sftp-client to make development of this node easy.
SFTP
List Directory - Lists contents of msg.payload as a directory OR working directory on node config.
Get - Set msg.payload to get the file OR working directory + file name in configuration will be used.
Put - Set msg.payload.data to either the file name, buffer stream, or buffer object of the source file. Set msg.payload.filename to the desired name of remote file. If msg.payload.filename is not specified filename in node config will be used. File contents will be uploaded to the SFTP server in the working directory specified.
Delete File - Set msg.payload to the name of the file you wish to delete in the working directory.
Rename - Set msg.payload.filename to the original name of remote file. Set msg.payload.newfilename to the new name of remote file. If msg.payload.filename and msg.payload.newfilename is not specified filename and newfilename in node config will be used. File will be renamed to the SFTP server in the working directory specified.
Make Directory - Set msg.payload to the name of the directory to make. If blank working directory will be used.
Remove Directory - Set msg.payload to the name of the directory to remove. If blank working directory will be used.
Host, username, and password are required to configure a new SFTP client.
Algorithms are set to pre-defined default values. If you need to modify them see ssh2-streams for more information.
See license
Version: 1.0.0
Updated 1 year, 10 months ago
3 in the last week
  • sftp in
  • sftp
  • sftp
  • file
  • redconnect
