node-red-contrib-balena 1.0.1
A set of nodes to interact with balena.io supervisor from node-red
npm install node-red-contrib-balena
A set of nodes that allow to interact with balena supervisor from Node-RED on balena
this set of nodes works only on balena applications, check balena-node-red for deploying Node-RED on balena
npm i node-red-contrib-balena -g
nodes
A wrapper for balena-supervisor blink endpoint
Returns the HTTP Status Code
Ping
A wrapper for balena-supervisor ping endpoint
Device
A wrapper for balena-supervisor device state endpoint
Returns a device state JSON object
Restart
A wrapper for balena-supervisor container restart endpoint
Reboot
A wrapper for balena-supervisor reboot endpoint
Shutdown
A wrapper for balena-supervisor shutdown endpoint
Purge
A wrapper for balena-supervisor data purge endpoint
Returns a JSON object
Lock
sets the update lockfile, more info here
returns true when the action completes, throws an error and returns false when the action fails
Unlock
removes the update lockfile, more info here
Update
A wrapper for balena-supervisor update endpoint with lock override
Changelog
please see CHANGELOG.md
Copyright 2016 balena Ltd.
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at
Version: 1.0.1
Updated 5 years ago
6 in the last week
  • blink
  • device
  • ping
  • restart
  • reboot
  • shutdown
  • purge
  • lock
  • unlock
  • update
  • balena
  • io
  • supervisor
  • device
