node-red-contrib-azure-table-storage 0.1.4
Connector to Azure Table Storage on Node-Red
npm install node-red-contrib-azure-table-storage
Node-Red node to connect to Azure Table Storage
Node-RED nodes to talk to Azure Storage.
Some code of Azure are under MIT License.
Azure node. Can be used to save Entity, retrieve Entity and query on Azure Table Storage:
  • Supports :
◦Create/Delete Tables ◦Create/Read/Delete/Update Entities
Still working on query Entities.
Use msg.payload to send a string with all data what you want to excute something on Azure Table Storage. Pay attention on each action variable.
To save entity
Ex: 'msg.payload' -> {"tableName": "name", "action": "I", "partitionKey": "part1", "rowKey": "row1", "data": "data"}
  • If you send data as JSON, the node will convert to String and save into Table Storage in a column named "data".
##To read entity Ex: 'msg.payload' -> {"tableName": "name", "action": "R", "partitionKey": "part1", "rowKey": "row1"}
To delete entity
Ex: 'msg.payload' -> {"tableName": "name", "action": "D", "partitionKey": "part1", "rowKey": "row1"}
To update entity
Ex: 'msg.payload' -> {"tableName": "name", "action": "U", "partitionKey": "part1", "rowKey": "row1", "data": "data"}
To query entity
Ex: 'msg.payload' -> {"tableName": "name", "action": "Q", "selectdata": "columnName", "fromcolumn": "from", "where": "where"}
##To delete table Ex: 'msg.payload' -> {"tableName": "name", "action": "DT"}
Read more about Azure Storage on Azure Storage.
Version: 0.1.4
Updated 9 years, 5 months ago
30 in the last week
  • Table Storage
  • Azure
  • Azure Storage
  • Storage
  • Table Storage
