node-red-contrib-azure-sql 0.0.3
Connector to Azure SQL Database on Node-Red
npm install node-red-contrib-azure-sql
Node-RED nodes to talk to Azure SQL Database.
Some code of Azure are under MIT License.
Azure node. Can be used to work with Azure SQL Database
  • Supports :
‚ó¶Select (query) into Azure SQL
Still working to insert new data.
##How to use:
You must have create the database before to use. You will use:
  • Azure SQL URL (endpoint)
  • Login
  • Password
  • Database name
Use msg.payload to query data into Database.
Ex: 'msg.payload' -> {"action": "Q", "query" : "SELECT * FROM table WHERE firstName = 'Lucas'"};
Read more about Azure SQL Database on Azure SQL Database.
Version: 0.0.3
Updated 11 months, 2 weeks ago
3 in the last day
22 in the last week
93 in the last month
  • Azure SQL
  • Azure
  • SQL Database
  • SQL
  • luhumenh
