node-red-contrib-azure-documentdb 0.0.3
Connector to Azure DocumentDB on Node-Red
Node-RED nodes to talk to Azure DocumentDB.
Some code of Azure are under MIT License.
npm install node-red-contrib-azure-documentdb
Azure node. Can be used to work with Azure DocumentDB using 3 nodes:
- Supports :
◦CRUD Database and Collections ◦Create/List/Update/Delete and Query Documents
##Database Node
Use msg.payload
to create, delete and list the Database name.
Ex: 'msg.payload' -> {"dbname": "databaseName", "action": "C"};
put "C" to crete a Database - If you create a new database, the node will send as output the name of Database.
put "L" to list Database
put "D" to delete a Database
##Collections Node
Use msg.payload
to create, delete and list the Collection name.
Ex: 'msg.payload' -> {"dbname": "databaseName", "collName": "colletionName", "action": "C"};
- put "C" to crete a Collection
- put "L" to list Collection
- put "D" to delete a Collection
##Documents Node
Use msg.payload
to work with documents in DocumentDB
Ex: 'msg.payload' -> {"dbname": "databaseName", "collName": "colletionName", "action": "C", "doc": "*"};
- put "C" to crete a Document - * Doc as JSON -> {"name": "Lucas", "lastname": "Humenhuk"}
- put "L" to list Documents
- put "D" to delete a Document
- put "U" to update a Document
- put "Q" to query a document - To query a document. Ex: 'SELECT VALUE r.address FROM root r WHERE r.firstname = "Lucas"'
Read more about Azure DocumentDB on Azure DocumentDB.
