node-red-contrib-aws-iot-hub 0.1.14
An aws-iot-hub node for Node-RED
npm install node-red-contrib-aws-iot-hub
A Node-Red node to read and write to the Amazon Web Services AWS IoT.
  • Install your AWS certificates into your local folder where node-red can reach your directory
    Example:
	/root/.agent/certs/-
					|--YourThingName.private.key
					|--YourThingName.cert.pem
					|--root-CA.crt
YourThingName is the AWS Thing name what is the value you keyin when creating your thing/device.
  • Setup the node-red-contrib-aws-iot-hub node with AWS Certs path pointed to /root/.agent/certs/
    Example:
	awsCerts = /root/.agent/certs/
  • The final configuration will be used in the node-red-contrib-aws-iot-hub code look likes:
	keyPath : '/root/.agent/certs/YourThingName.private.key',
	certPath : '/root/.agent/certs/YourThingName.cert.pem',
	caPath : '/root/.agent/certs/root-CA.crt',
	clientId : YourThingName,
	host : <YourAWSIoTCustomEndpoint>
See more at https://github.com/aws/aws-iot-device-sdk-js/blob/master/README.md#certificate-configuration
Version: 0.1.14
Rating: 0.0
43 in the last week
  • aws-iot-device
  • aws-mqtt out
  • aws-mqtt in
  • aws-thing
  • aws-iot
