node-red-contrib-aws-cloudsearch 1.1.0
node for aws cloudsearch
npm install node-red-contrib-aws-cloudsearch
Check it out! Now you can access your AWS Cloudsearch data with Node-RED! This allows you to fetch AWS Cloudsearch data using node-red nodes.
Installing node-red-contrib-aws-cloudsearch
cd ~/.node-red  #or wherever node-red is installed
npm i node-red-contrib-aws-cloudsearch
The params passed to searchdomain are picked from the msg payload. There are 2 options to pass the params
  1. Add a key 'params' to msg object and pass along all the parameters.
    msg.params = {
        query : "(and gender:'Men')",
        queryParser: "structured",
  2. Add individual parameters directly to msg object.
      msg.query = "(and gender:'Men')";
      msg.query = "structured";
      msg.size  = 10;
Refer CloudSearchDomain SDK for supported params
TODO
Only search is supported now. Suggest and Upload documents needs to be added.
Have questions? Found a bug?
Please submit issues to the Github issue tracker
Version: 1.1.0
Updated 6 years, 10 months ago
1 in the last week
  • aws-cloudsearch
  • aws-cloudsearch-suggest
  • aws-config
  • aws-cloudsearch-config
  • node
  • aws
  • cloudsearch
