node-red-contrib-average 0.1.7
A Node-RED node to calculate average.
npm install node-red-contrib-average
GitHub version NPM version Dependencies Status
A Node-RED node to calculate average (avg).
Table of Contents
Run the following command in your Node-RED user directory - typically ~/.node-red:
Calculate the average of incoming msg.payload values from across a number of different msg.topic.
Incoming msg.topic has to be used to separate and identify values. Messages not containing a valid numeric value will be rejected.
Will return the current average of all different msg.topic values as msg.payload. Every other data will be pushed through.
The average can be reset with an incoming message that contains msg.reset. Then all stored data will be removed and the initial average starts at zero again.
Example Flow
Simple example showing how to calculate and average of static values.
[{"id":"5a8eea2a.b67d3c","type":"debug","z":"470977d9.9fb538","name":"debug","active":true,"console":"false","complete":"true","x":870,"y":200,"wires":[]},{"id":"c79942e7.6ae498","type":"inject","z":"470977d9.9fb538","name":"1","topic":"name_one","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"x":470,"y":80,"wires":[["60d50df3.aacf5c"]]},{"id":"5b6c2de0.a35dc4","type":"inject","z":"470977d9.9fb538","name":"2","topic":"name_two","payload":"2","payloadType":"num","repeat":"","crontab":"","once":false,"x":470,"y":120,"wires":[["60d50df3.aacf5c"]]},{"id":"689a005a.9f41b8","type":"inject","z":"470977d9.9fb538","name":"3","topic":"name_three","payload":"3","payloadType":"num","repeat":"","crontab":"","once":false,"x":470,"y":160,"wires":[["60d50df3.aacf5c"]]},{"id":"4b264eb1.263c88","type":"inject","z":"470977d9.9fb538","name":"4","topic":"name_four","payload":"4","payloadType":"num","repeat":"","crontab":"","once":false,"x":470,"y":200,"wires":[["60d50df3.aacf5c"]]},{"id":"60d50df3.aacf5c","type":"average","z":"470977d9.9fb538","name":"","topic":"","x":740,"y":200,"wires":[["5a8eea2a.b67d3c"]]},{"id":"96ae6e69.adecc8","type":"inject","z":"470977d9.9fb538","name":"reset","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":470,"y":240,"wires":[["49c46c67.385fc4"]]},{"id":"49c46c67.385fc4","type":"function","z":"470977d9.9fb538","name":"msg","func":"msg.reset = true;\nreturn msg;","outputs":1,"noerr":0,"x":590,"y":240,"wires":[["60d50df3.aacf5c"]]}]
Bugs / Feature request
Please report bugs and feel free to ask for new features directly on GitHub.
This project is licensed under Apache 2.0 license.
Donation
You like to support me?
You appreciate my work?
You use it in commercial projects?
Feel free to make a little donation! :wink:
Version: 0.1.7
Rating: 3.0 2
65 in the last week
  • average
  • average
  • avg
