node-red-contrib-async 0.0.4
Based on node-red-node-function. A function block that allows you to output messages to other nodes asynchronously.
npm install node-red-contrib-async
A node-red node for executing javascript code in a node-red flow either synchronously, asynchronously, or both. Based on the node-red core function node.
In the node-red package.json add a dependency to "node-red-contrib-async":"latest"
Usage is documented in the node's information panel.
Version: 0.0.4
Updated 12 years, 8 months ago
License: Apache
7 in the last week
  • async
  • asynchronous
  • function
  • callback
