node-red-contrib-asakusa_giken 4.0.0
Node-RED nodes for Asakusa Giken Devices
npm install node-red-contrib-asakusa_giken
GitHub release master Build Status License MIT
This project offers the following BLE device nodes manufactured by Asakusa Giken.
  1. BLEIo ... GPIO BLE board
  2. BLECAST_ENV ... A BLE multi-sensor device (temperature, humidity and illuminance)
The following nodes are no longer included:
  1. BLECAST_TM ... A BLE temperature sensor device
  2. BLECAST_BL ... A BLE illuminance sensor device
浅草ギ研 BLECAST Node-RED ノード
浅草ギ研 BLE対応製品の以下のデバイスに対応したNode-REDノードです。
  1. BLEIo ... 汎用I/O BLEモジュール
  2. BLECAST_ENV ... BLE温湿度&照度センサー
以下のノードは、初期設定では使用できません。使用するには、バージョン3のノードをインストールしてください。
  1. BLECAST_TM ... BLE 温度センサー
  2. BLECAST_BL ... BLE 照度センサー
サンプルフロー
BLEIo向けのサンプルフローexample-flow.json が利用可能です。クリックして中身を表示してから全体をコピーし、Node-REDのImportからClipboardを選択して内容を貼り付けてください。
cd ~/.node-red # or your own userDir where Node-RED saves flow file
npm install --unsafe-perm node-red-contrib-asakusa_giken
Development
Tools
Then, try this.
$ npm install --unsafe-perm
How to build
$ npm run build
will generate ES5 js files.
Revision History
  • 4.0.0
  • 3.0.4
    • Remove redundant dependency
  • 3.0.3
    • Fix an issue where BLE scanning stopped after connecting to a BLE peripheral
  • 3.0.2
    • Fix an issue where node events weren't occasionally transmitted to configuration nodes
  • 3.0.1
    • Fix an issue where LCD showed dot characters as blank spaces
    • Fix an issue where some of DOUT and PWM values weren't applied properly
    • Improve the example flow
  • 3.0.0
    • Add a new node for BLECAST_ENV
  • 2.0.4
    • Fix an issue where BLEIo node failed to write a valid value because of wrong value translation
  • 2.0.3
    • Fix an issue where blecast module threw undefined error
  • 2.0.2
    • Fix an issue where Chrome browser failed to evaluate variable declarations because of a lack of 'use restrict'
    • Fix an issue where BLECAST_BL and BLECAST_TM descriptions were missing
  • 2.0.1
    • Fix an issue where noble with Bluez didn't fire a discover event once a peripheral was connected
  • 2.0.0
    • Add a new node for BLEIo
  • 1.2.0
    • Reset BLE address cache on deploying nodes
  • 1.1.0
    • Fix an issue where registered BLE peripherals are remained after the corresponding nodes are gone
    • Update git repo URLs
  • 1.0.1
    • Initial public release
Copyright and License
PNG images under icon folder are released under CC BY-NC-SA, copyright 2016 CANDY LINE INC..
The project is released under MIT License. See LICENSE for detail.
Version: 4.0.0
Updated 3 weeks, 3 days ago
0 in the last day
15 in the last week
206 in the last month
  • bluetooth
  • raspbian
  • BLE
  • bluetooth low energy
  • bluetooth smart
  • central
  • CANDY RED
  • CANDY EGG
  • dbaba
