node-red-contrib-as400 0.0.2
A Node-RED node to use a AS400 system
npm install node-red-contrib-as400
A Node-RED node to read and write to a AS400 system.
Allows basic access to a AS400 system.
The msg.payload must hold the query
and the result is returned in msg.payload.
Each row will send a new payload, so you can work with big results.
The last row sends also a msg.complete message, so you can join the results.
If nothing is found for the key then null is returned.
Version: 0.0.2
Updated 7 years, 6 months ago
9 in the last week
  • as400
  • as400
