node-red-contrib-apcaccess 1.0.2
Node-RED nodes to request status and events from an APC UPS Daemon NIS running on the network.
npm install node-red-contrib-apcaccess
npm version
NPM
Screenshot
Prerequisites
An APC UPS Daemon has to run on a local or remote machine and has to be configured as network information server (NIS). For more information visit the apcupsd website.
Server Configuration Node
Configure the APC UPS Daemon NIS settings to connect to. You can either use an ip address or hostname combined with the port of the server (default: 3551).
Request Node
This node allows you to send request to an APC UPS Daemon Network Information Server (apcupsd NIS). Currently it supports the following commands:
  • status
  • events
  • statusJson
Use one of the mentioned commands as payload of the input message. It will output a string with the result or in case of statusJson an Object containing the current status of the APC UPS.
Example Outputs
Command: status
APC      : 001,034,0839
DATE     : 2017-04-30 13:41:04 +0200
HOSTNAME : alarmpi
VERSION  : 3.14.14 (31 May 2016) unknown
UPSNAME  : alarmpi
CABLE    : USB Cable
DRIVER   : USB UPS Driver
UPSMODE  : Stand Alone
STARTTIME: 2017-04-28 12:04:47 +0200
MODEL    : Back-UPS ES 700G
STATUS   : ONLINE
LINEV    : 232.0 Volts
LOADPCT  : 5.0 Percent
BCHARGE  : 100.0 Percent
TIMELEFT : 36.4 Minutes
MBATTCHG : 5 Percent
MINTIMEL : 3 Minutes
MAXTIME  : 0 Seconds
SENSE    : Medium
LOTRANS  : 180.0 Volts
HITRANS  : 266.0 Volts
ALARMDEL : 30 Seconds
BATTV    : 13.5 Volts
LASTXFER : Unacceptable line voltage changes
NUMXFERS : 0
TONBATT  : 0 Seconds
CUMONBATT: 0 Seconds
XOFFBATT : N/A
STATFLAG : 0x05000008
SERIALNO : 5B1325T16968
BATTDATE : 2013-06-23
NOMINV   : 230 Volts
NOMBATTV : 12.0 Volts
FIRMWARE : 871.O2 .I USB FW:O2
END APC  : 2017-04-30 13:41:26 +0200
Command: events
2017-04-28 12:01:15 +0200  Cannot create /run/apcupsd/LCK.. serial port lock file: ERR=No such file or directory
2017-04-28 12:01:15 +0200  apcupsd FATAL ERROR in apcupsd.c at line 221
Unable to create UPS lock file.
  If apcupsd or apctest is already running,
  please stop it and run this program again.
2017-04-28 12:01:15 +0200  apcupsd error shutdown completed
2017-04-28 12:01:35 +0200  Cannot create /run/apcupsd/LCK.. serial port lock file: ERR=No such file or directory
2017-04-28 12:01:35 +0200  apcupsd FATAL ERROR in apcupsd.c at line 221
2017-04-28 12:01:35 +0200  apcupsd error shutdown completed
2017-04-28 12:04:47 +0200  apcupsd 3.14.14 (31 May 2016) unknown startup succeeded
Command: statusJson
{ APC: '001,034,0839',
  DATE: '2017-04-30 13:47:07 +0200  ',
  HOSTNAME: 'alarmpi',
  VERSION: '3.14.14 (31 May 2016) unknown',
  UPSNAME: 'alarmpi',
  CABLE: 'USB Cable',
  DRIVER: 'USB UPS Driver',
  UPSMODE: 'Stand Alone',
  STARTTIME: '2017-04-28 12:04:47 +0200  ',
  MODEL: 'Back-UPS ES 700G ',
  STATUS: 'ONLINE ',
  LINEV: '232.0 Volts',
  LOADPCT: '5.0 Percent',
  BCHARGE: '100.0 Percent',
  TIMELEFT: '36.4 Minutes',
  MBATTCHG: '5 Percent',
  MINTIMEL: '3 Minutes',
  MAXTIME: '0 Seconds',
  SENSE: 'Medium',
  LOTRANS: '180.0 Volts',
  HITRANS: '266.0 Volts',
  ALARMDEL: '30 Seconds',
  BATTV: '13.5 Volts',
  LASTXFER: 'Unacceptable line voltage changes',
  NUMXFERS: '0',
  TONBATT: '0 Seconds',
  CUMONBATT: '0 Seconds',
  XOFFBATT: 'N/A',
  STATFLAG: '0x05000008',
  SERIALNO: '5B1325T16968  ',
  BATTDATE: '2013-06-23',
  NOMINV: '230 Volts',
  NOMBATTV: '12.0 Volts',
  FIRMWARE: '871.O2 .I USB FW:O2',
  'END APC': '2017-04-30 13:47:10 +0200  ' }
Example
[{"id":"8f31665a.668f48","type":"apcrequest","z":"5517edea.ed19e4","name":"apc","server":"afa3f4e3.795558","x":435.5,"y":102,"wires":[["2e628a77.cc2d76"]]},{"id":"47122c35.9c5f84","type":"inject","z":"5517edea.ed19e4","name":"","topic":"Test","payload":"status","payloadType":"str","repeat":"","crontab":"","once":false,"x":189,"y":72,"wires":[["8f31665a.668f48"]]},{"id":"2e628a77.cc2d76","type":"debug","z":"5517edea.ed19e4","name":"","active":true,"console":"false","complete":"false","x":641,"y":102,"wires":[]},{"id":"de2b47a8.eb6b08","type":"inject","z":"5517edea.ed19e4","name":"","topic":"Test","payload":"events","payloadType":"str","repeat":"","crontab":"","once":false,"x":182,"y":110,"wires":[["8f31665a.668f48"]]},{"id":"70fc817d.84b88","type":"inject","z":"5517edea.ed19e4","name":"","topic":"Test","payload":"statusJson","payloadType":"str","repeat":"","crontab":"","once":false,"x":176,"y":146,"wires":[["8f31665a.668f48"]]},{"id":"afa3f4e3.795558","type":"apcconfig","z":"5517edea.ed19e4","name":"localhost","host":"127.0.0.1","port":"3551"}]
Authors
This project is licensed under the MIT License - see the LICENSE.md file for details
Version: 1.0.2
Updated 2 weeks, 1 day ago
1 in the last day
23 in the last week
197 in the last month
  • apcconfig
  • apcrequest
  • apcupsd
  • apcaccess
  • apc
  • ups
  • uninterruptible power supply
  • nis
  • mapero
