node-red-contrib-adxl-vibration-fft 3.1.0
Node-RED nodes for Analog Devices' ADXL series FFT(Fast Fourier Transform) stream data parser
npm install node-red-contrib-adxl-vibration-fft
GitHub release master Build Status
Node-RED nodes for Vibration Measurement using:
  1. Analog Devices' EVAL-ADXL100X Vibration Sensor Evaluation Board and EV-COG-AD4050 ARM Cortex M4F MCU with the special firmware for FFT (Fast Fourier Transform)
  2. EMQuest-VA by UQUEST, LTD.
The nodes work with other MCU boards using the same UART protocol as the above firmware as well.
Vibration Sensor Device
Example Flow
The bundled example flow provides the following demonstrations:
  • Show FFT value chart with FFT peak value refreshed every second on Dashboard
  • Show FFT peak value (frequency and amplitude) on Dashboard
Prerequisites
Supported Hardwares
Analog Devices
UQUEST, LTD.
  • EMQuest-VA with an extra USB serial cable
  • Frequency range is 0.05-1.5KHz.
Software
Analog Devices
  • Firmware for this node is available at analog.com/jp. User registration is required.
UQUEST, LTD.
  • Firmware is pre-installed (proprietary licensed software)
How to install
Node-RED users
Use Manage Palette dialog in the browser editor or run the following commands:
Then restart Node-RED process.
Uninstallation
The following command uninstalls SmartMesh SDK python executables/libraries as well as this node package.
sudo npm uninstall --unsafe-perm node-red-contrib-adxl-vibration-fft
CANDY RED users
cd /opt/candy-red/.node-red
sudo npm install --unsafe-perm node-red-contrib-adxl-vibration-fft
Then restart candy-red service.
sudo systemctl restart candy-red
Uninstallation
Manage Palette dialog should work for uninstallation as well as the following commands:
The above command uninstalls SmartMesh SDK python executables/libraries as well as this node package.
Appendix
How to build
# build
$ NODE_ENV=development npm run build
# package
$ NODE_ENV=development npm pack
Revision History
  • 3.1.0
    • Add an experimental feature to read data from UQUEST EMQuest-VA with ADXL1002
  • 3.0.1
    • Fix an issue where sensor data was not sent after reconnecing serialport
  • 3.0.0
    • Add support for new edge device (UQUEST EMQuest-VA)
    • Improve serialport reconnection
  • 2.0.0
    • Fix an issue where the node didn't work on Node-RED v1+
  • 1.1.1
    • Fix node definition errors
  • 1.1.0
    • Add Node.js v12 support
    • Drop Node.js v8 support
  • 1.0.1
    • Add help text
  • 1.0.0
    • Initial Release
Version: 3.1.0
Updated 3 years ago
4 in the last week
  • ADXL100x FFT in
  • ADXL100x FFT
  • Vibration Sensor
  • ADXL1001
  • ADXL1002
  • ADXL356
  • EMQuest-VA
  • Fast Fourier Transform
  • FFT
  • Analog Devices
  • UQUEST, LTD.
  • Raspberry Pi
  • ASUS TinkerBoard
  • CANDY RED
  • CANDY EGG
