node-red-contrib-advanced-ping 1.2.0
A Node-RED node which takes input and pings a remote server.
npm install node-red-contrib-advanced-ping
This is a modification of the node-red-node-ping node. Difference is that this node will perform a ping when it recieves input where the node-red-node-ping node performs pings on a set interval. You may also programmatically pass ping settings to this node. For periodical checks, wire an inject node to this ping node.
  • Pings a machine and returns the trip time in ms. Ping time is returned in msg.payload. Returns boolean false if no response received within 5 seconds, or if the host is unresolveable.
  • Will perform ping on any input.
  • You may override the host set in the configuration by passing in a value in msg.host.
  • For legacy reasons, the node will output the host as msg.topic (the original node-red-node-ping does it this way).
  • Any incomming data will be passed on to the output.
    • Incoming msg.payload data will be outputted as msg._payload (as the new msg.payload will contain the result of the ping).
    • Incoming msg.topic data will be outputted as msg._topic (as the new msg.topic will contain the the host).
Todo
Ability to set ping options in node configuration/by incomming message. Right now, these settings are hardcoded
  • Linux: -n -w 5 -c 1
  • Windows: -n 1 -w 5000
  • Mac: -n -t 5 -c 1
Version: 1.2.0
Updated 12 years, 9 months ago
License: Apache
48 in the last week
  • adv ping
  • node-red-contrib
  • contrib
  • ping
