node-red-contrib-1wire 0.0.2
A Node-RED node to read a 1-wire temperature sensor
npm install node-red-contrib-1wire
A Node-RED node to read a 1-wire DS18B20 temp sensor.
This node uses the built in GPIO pins to read the 1-wire sensor. This must be enabled in the /boot/config.txt using parameters such as: dtoverlay=w1-gpio,gpiopin=4 Once enabled you should see the sensor information at /sys/bus/w1/devices/
npm install -g .
Provide the identifier for the 1-wire sensor to read The msg.topic will contain the sensor identifier The msg.payload will contain the termpature in degrees C
Version: 0.0.2
Updated 3 years, 9 months ago
License: Apache
Rating: 2.5 2
18 in the last week
  • 1-Wire
