iont-node-red-contrib-aws-iot-hub 0.1.18
An aws-iot-hub node for Node-RED
npm install iont-node-red-contrib-aws-iot-hub
A Node-Red node to read and write to the Amazon Web Services AWS IoT.
npm install node-red-contrib-aws-iot-hub
  • Install your AWS certificates into your local folder where node-red can reach your directory
    Example:
    /root/.agent/certs/-
                    |--YourThingName.private.key
                    |--YourThingName.cert.pem
                    |--root-CA.crt
YourThingName is the AWS Thing name what is the value you keyin when creating your thing/device.
  • Setup the node-red-contrib-aws-iot-hub node with AWS Certs path pointed to /root/.agent/certs/
    Example:
    awsCerts = /root/.agent/certs/
  • The final configuration will be used in the node-red-contrib-aws-iot-hub code look likes:
    keyPath : '/root/.agent/certs/YourThingName.private.key',
    certPath : '/root/.agent/certs/YourThingName.cert.pem',
    caPath : '/root/.agent/certs/root-CA.crt',
    clientId : YourThingName,
    host : <YourAWSIoTCustomEndpoint>
See more at https://github.com/aws/aws-iot-device-sdk-js/blob/master/README.md#certificate-configuration
Version: 0.1.18
Updated 7 years ago
7 in the last week
  • aws-iot-device
  • aws-mqtt out
  • aws-mqtt in
  • aws-thing
  • aws-iot
