formio-red 0.2.0
Form.io Node Red Integration
npm install formio-red
This provides a few nodes which makes working with the Form.io platform within Node Red much easier.
You must first install Node Red and have it running locally to use this. Go to http://nodered.org/ to learn more.
Once you have this running, change directory to your .node-red folder, and then type the following.
You will now have two nodes to pick from.
  • formio save (storage): This will save a new form submission.
  • formio get (storage): This will retrieve a list of submissions based on a query provided in msg.query.
  • formio in (input): This will receive a Form.io form webhook to use forms as input.
Important Note: When using the Form.io input node, you must provide the following Authentication settings in your Form.io Webhook Action settings. These should be configured as follows.
  • Authorize User: admin
  • Authorize Password: [YOUR PROJECT API KEY]
Enjoy!
  • The Form.io Team
Version: 0.2.0
Updated 8 years ago
2 in the last week
  • formio
  • formio save
  • form_io in
  • formio get
  • formio
  • form.io
  • Travis Tidwell
