Smick_007_Soil_Moisture_v2
This flow shows the use of analog sensors (potentiometer, LDR, ...). You will learn how to configure Smick to generate:
- Measurement sequences read from the sensor;
- The LOW event when measurements fall below a certain threshold;
- The High event when measurements exceed a certain threshold. The associated dashboard allows you to:
- Enable / disable these events;
- Measurements of real-time display on a received indicator (gauge);
- Displays the last LOW / HIGH detected and sent to e-mail alarm and Twitter.
[{"id":"2e5366e1.c42d6a","type":"comment","z":"d86c452a.8b5f88","name":"Description","info":"Questo flusso mostra l'uso del sensore analogico Soil Moisture per misurare il grado di umidità del suolo.\nSi apprenderà come configurare smick per generare:\n- sequenze di misure lette dal sensore;\n- l'evento DRY (secco) quando le misure scendono al di sotto di una soglia data;\n- l'evento WET (umido) quando le misure superano una soglia data.\nLa dashboard associata consente di:\n- abilitare/disabilitare i suddetti eventi;\n- di visualizzare in tempo reale le misure ricevute su un indicatore (gauge);\n- di visualizzare l'ultimo allarme LOW/HIGH rilevato ed inviato su e-mail e twitter.\n\n\nThis flow shows the use of analog sensors (potentiometer, LDR, ...).\nYou will learn how to configure Smick to generate:\n- Measurement sequences read from the sensor;\n- The LOW event when measurements fall below a certain threshold;\n- The High event when measurements exceed a certain threshold.\nThe associated dashboard allows you to:\n- Enable / disable these events;\n- Measurements of real-time display on a received indicator (gauge);\n- Displays the last LOW / HIGH detected and sent to e-mail alarm and Twitter.","x":110,"y":40,"wires":[]},{"id":"82435511.10dbd8","type":"link out","z":"d86c452a.8b5f88","name":"command","links":["d00f3010.4b85b"],"x":935,"y":360,"wires":[]},{"id":"6d497ad8.a565a4","type":"comment","z":"d86c452a.8b5f88","name":"actions on actuators","info":"","x":750,"y":260,"wires":[]},{"id":"36f877bb.ff76c8","type":"comment","z":"d86c452a.8b5f88","name":"actions on dashboard","info":"","x":780,"y":580,"wires":[]},{"id":"6dd255c3.c14c1c","type":"e-mail","z":"d86c452a.8b5f88","server":"smtp.gmail.com","port":"465","name":"[email protected]","dname":"mail","x":710,"y":460,"wires":[]},{"id":"939d133d.1e25f","type":"twitter out","z":"d86c452a.8b5f88","twitter":"","name":"tweet","x":710,"y":520,"wires":[]},{"id":"6e49feaa.a7289","type":"comment","z":"d86c452a.8b5f88","name":"actions on social","info":"","x":740,"y":400,"wires":[]},{"id":"79ade2b4.cd35cc","type":"function","z":"d86c452a.8b5f88","name":"alarm msg","func":"function timeDate(tz) {\n var d = new Date(Date.now()+tz*3600000);\n\n return d.getUTCHours() + \":\" +\n d.getUTCMinutes() + \":\" +\n d.getUTCSeconds() + \" \" +\n d.getUTCDate()\t+\"/\" +\n (d.getUTCMonth()+1) + \"/\" +\n d.getUTCFullYear();\n}\n\nmsg.payload=msg.payload + \" level alarm at \" + timeDate(1);\nreturn msg;","outputs":1,"noerr":0,"x":530,"y":640,"wires":[["272a5e87.4356d2","c0e3f285.429a8"]]},{"id":"360231a3.319a9e","type":"comment","z":"d86c452a.8b5f88","name":"events","info":"","x":250,"y":280,"wires":[]},{"id":"e20a83db.438a5","type":"comment","z":"d86c452a.8b5f88","name":"Licence & History","info":"Package : Smick v.1\nModule : LED - digital output\nAuthor : Curci\nLicence : (CC) BY-NC-SA\n\nThis work is licensed under a Creative Commons \nAttribution-NonCommercial-ShareAlike \n4.0 International License.\n\nHistory\n\nDate Author Description\n2016.12.17 Curci genesis","x":280,"y":40,"wires":[]},{"id":"6af68079.2e2fc","type":"comment","z":"d86c452a.8b5f88","name":"BOM","info":"Bill Of Material\n\nHardware:\n\n 1 Human internet terminal (PC, tablet or smartphone) connected to the internet\n 1 Smick Wi-Fi connected to the internet\n 1 Pot | LDR + 10kohm resistor | Soil Moisture sensor + 10kohm resistor\n\nHW Connections:\n\n Device pin Smick pin\n Pot left GND\n Pot center A0\n Pot right 3.3V\n \n or \n \n Device pin Smick pin \n LDR 1 GND\n LDR 2 A0\n R 10k 1 A0\n R 10k 2 3.3V\n\n or\n \n Device pin Smick pin \n SM 1 GND\n SM 2 A0\n R 10k 1 A0\n R 10k 2 3.3V\n \nFlow Connections:\n\n Smick_001_console\n\nAccount:\n\n Wi-Fi credentials\n MQTT broker\n FRED\n E-mail\n Twitter\n","x":430,"y":40,"wires":[]},{"id":"c2460e79.0941a","type":"ui_gauge","z":"d86c452a.8b5f88","name":"soil moisture","group":"394dacb6.3739c4","order":2,"width":0,"height":0,"gtype":"gage","title":"sensor","label":"","format":"{{value}}%","min":0,"max":"100","colors":["#ff0000","#00ff00","#0000ff"],"x":790,"y":860,"wires":[]},{"id":"a87d5f44.bf3ee","type":"comment","z":"d86c452a.8b5f88","name":"enable/disable","info":"","x":740,"y":180,"wires":[]},{"id":"272a5e87.4356d2","type":"debug","z":"d86c452a.8b5f88","name":"","active":true,"console":"false","complete":"payload","x":790,"y":700,"wires":[]},{"id":"c0e3f285.429a8","type":"ui_text","z":"d86c452a.8b5f88","group":"394dacb6.3739c4","order":3,"width":0,"height":0,"name":"alarm msg","label":"last alarm","format":"{{msg.payload}}","layout":"col-center","x":790,"y":640,"wires":[]},{"id":"66aa6c62.11ec94","type":"ui_dropdown","z":"d86c452a.8b5f88","name":"","label":"mode","group":"394dacb6.3739c4","order":1,"width":0,"height":0,"passthru":true,"options":[{"label":"disable","value":"A0==NULL","type":"str"},{"label":"enable","value":"A0@1","type":"str"},{"label":"set DRY alarm","value":"DRY==A0<100","type":"str"},{"label":"set WET alarm","value":"WET==A0>500","type":"str"}],"payload":"","topic":"","x":710,"y":320,"wires":[["82435511.10dbd8"]]},{"id":"b983a1a0.63139","type":"debug","z":"d86c452a.8b5f88","name":"","active":true,"console":"false","complete":"payload","x":790,"y":800,"wires":[]},{"id":"1bdf2ee.17d20d1","type":"range","z":"d86c452a.8b5f88","minin":"0","maxin":"600","minout":"0","maxout":"100","action":"roll","round":true,"name":"%","x":550,"y":820,"wires":[["c2460e79.0941a","b983a1a0.63139"]]},{"id":"e6305255.f5035","type":"link in","z":"d86c452a.8b5f88","name":"response_event","links":["290027bd.4e4828"],"x":175,"y":660,"wires":[["1ad78b9f.f2fe54"]]},{"id":"1ad78b9f.f2fe54","type":"switch","z":"d86c452a.8b5f88","name":"parse","property":"payload","propertyType":"msg","rules":[{"t":"regex","v":"DRY|WET","vt":"str","case":false},{"t":"else"}],"checkall":"false","outputs":2,"x":270,"y":660,"wires":[["79ade2b4.cd35cc","272a5e87.4356d2"],["1bdf2ee.17d20d1"]]},{"id":"394dacb6.3739c4","type":"ui_group","z":"","name":"Soil Moisture","tab":"d364a88e.ef3468","order":1,"disp":true,"width":"6"},{"id":"d364a88e.ef3468","type":"ui_tab","z":"","name":"Soil Moisture","icon":"dashboard","order":6}]
