MySensors v2 Message Decoder
#MySensors v2 Message Decoder Decode every MySensors message according to the serial API specifications.
#Create a JSON object payload This flow create a JSON object as payload with the following key:value data :
nodeId : Node Id
sensorId : child Id
mode : presentation, set, req, internal, stream
type : sub-type depending to the message type
typeLabel : human readable label
value : MySensors payload
Projets DIY - 2016
http://www.projetsdiy.fr
Post (in french) : http://www.projetsdiy.fr/mysensors-decoder-envoyer-messages-node-red/
[{"id":"f4fd4940.32ba8","type":"function","z":"eb4ead14.fd77f","name":"Decode MySensor Message","func":"/* MySensors v2 Message Decoder\n*  Payload : JSON object\n*  www.projetsdiy.fr - oct. 2016\n*/\nvar mySensorsMessage = {}\nvar newPayload = {};\nvar message = msg.payload.toString();\nmessage = message.replace(/(\\r\\n|\\n|\\r)/gm, \"\");\nvar tokens = message.split(\";\")\nif(tokens.length == 6)\n{\n    mySensorsMessage.nodeId =       parseInt(tokens[0]);\n    mySensorsMessage.childSensorId= parseInt(tokens[1]);\n    mySensorsMessage.messageType =  parseInt(tokens[2]);\n    mySensorsMessage.ack =          parseInt(tokens[3]);\n    mySensorsMessage.subType =      parseInt(tokens[4]);\n    mySensorsMessage.value =        Number(tokens[5]);\n\n    var messageType = mySensorsMessage.messageType;\n    var subType = mySensorsMessage.subType;\n    var labelPresentation = [\"S_DOOR\",\"S_MOTION\",\"S_SMOKE\",\"S_LIGHT\",\"S_BINARY\",\"S_DIMMER\",\"S_COVER\",\"S_TEMP\",\"S_HUM\",\"S_BARO\",\"S_WIND\",\"S_RAIN\",\"S_UV\",\"S_WEIGHT\",\"S_POWER\",\"S_HEATER\",\"S_DISTANCE\",\"S_LIGHT_LEVEL\",\"S_ARDUINO_NODE\",\"S_ARDUINO_REPEATER_NODE\",\"S_LOCK\",\"S_IR\",\"S_WATER\",\"S_AIR_QUALITY\",\"S_CUSTOM\",\"S_DUST\",\"S_SCENE_CONTROLLER\",\"S_RGB_LIGHT\",\"S_RGBW_LIGHT\",\"S_COLOR_SENSOR\",\"S_HVAC\",\"S_MULTIMETER\",\"S_SPRINKLER\",\"S_WATER_LEAK\",\"S_SOUND\",\"S_VIBRATION\",\"S_MOISTURE\",\"S_INFO\",\"S_GAS\",\"S_GPS\",\"S_WATER_QUALITY\"];\n    var labelSet = [\"V_TEMP\",\"V_HUM\",\"V_STATUS\",\"V_LIGHT\",\"V_PERCENTAGE\",\"V_DIMMER\",\"V_PRESSURE\",\"V_FORECAST\",\"V_RAIN\",\"V_RAINRATE\",\"V_WIND\",\"V_GUST\",\"V_DIRECTION\",\"V_UV\",\"V_WEIGHT\",\"V_DISTANCE\",\"V_IMPEDANCE\",\"V_ARMED\",\"V_TRIPPED\",\"V_WATT\",\"V_KWH\",\"V_SCENE_ON\",\"V_SCENE_OFF\",\"V_HVAC_FLOW_STATE\",\"V_HVAC_SPEED\",\"V_LIGHT_LEVEL\",\"V_VAR1\",\"V_VAR2\",\"V_VAR3\",\"V_VAR4\",\"V_VAR5\",\"V_UP\",\"V_DOWN\",\"V_STOP\",\"V_IR_SEND\",\"V_IR_RECEIVE\",\"V_FLOW\",\"V_VOLUME\",\"V_LOCK_STATUS\",\"V_LEVEL\",\"V_VOLTAGE\",\"V_CURRENT\",\"V_RGB\",\"V_RGBW\",\"V_ID\",\"V_UNIT_PREFIX\",\"V_HVAC_SETPOINT_COOL\",\"V_HVAC_SETPOINT_HEAT\",\"V_HVAC_FLOW_MODE\",\"V_TEXT\",\"V_CUSTOM\",\"V_POSITION\",\"V_IR_RECORD\",\"V_PH\",\"V_ORP\",\"V_EC\",\"V_VAR\",\"V_VA\",\"V_POWER_FACTOR\"]\n    var labelInternal = [\"I_BATTERY_LEVEL\",\"I_TIME\",\"I_VERSION\",\"I_ID_REQUEST\",\"I_ID_RESPONSE\",\"I_INCLUSION_MODE\",\"I_CONFIG\",\"I_FIND_PARENT\",\"I_FIND_PARENT_RESPONSE\",\"I_LOG_MESSAGE\",\"I_CHILDREN\",\"I_SKETCH_NAME\",\"I_SKETCH_VERSION\",\"I_REBOOT\",\"I_GATEWAY_READY\",\"I_REQUEST_SIGNING\",\"I_GET_NONCE\",\"I_GET_NONCE_RESPONSE\",\"I_HEARTBEAT\",\"I_PRESENTATION\",\"I_DISCOVER\",\"I_DISCOVER_RESPONSE\",\"I_HEARTBEAT_RESPONSE\",\"I_LOCKED\",\"I_PING\",\"I_PONG\",\"I_REGISTRATION_REQUEST\",\"I_REGISTRATION_RESPONSE\",\"I_DEBUG\"]\n    \n    switch (messageType) {\n        case 0:     // Presentation\n            \n            newPayload.mode =       \"Presentation\";\n            newPayload.type =       labelPresentation[subType];\n            break;\n        case 1:     // Set\n            newPayload.nodeId=      mySensorsMessage.nodeId;\n            newPayload.sensorId=    mySensorsMessage.childSensorId;\n            newPayload.mode=        \"Set\";\n            newPayload.type=        subType;\n            newPayload.typeLabel=   labelSet[subType];\n            newPayload.value=       mySensorsMessage.value;\n            break;\n        case 2:     // Req\n            newPayload.nodeId=      mySensorsMessage.nodeId;\n            newPayload.sensorId=    mySensorsMessage.childSensorId;\n            newPayload.mode=        \"Req\";\n            newPayload.type=        subType;\n            newPayload.typeLabel=   labelSet[subType];\n            newPayload.value=       mySensorsMessage.value;\n            break;  \n        case 3:     // Internal\n            newPayload.nodeId=      mySensorsMessage.nodeId;\n            newPayload.sensorId=    mySensorsMessage.childSensorId;\n            newPayload.mode=        \"Internal\";\n            newPayload.type=        subType;\n            newPayload.typeLabel=   labelInternal[subType];\n            newPayload.value=       mySensorsMessage.value;\n            break;    \n        case 4:     // Stream - OTA firmware update\n            newPayload.nodeId=      mySensorsMessage.nodeId;\n            newPayload.mode=        \"stream\";\n            break;\n        default:\n            break;\n    }\n\n    msg.payload = newPayload; \n} else {\n    msg.payload = \"Error! Nothing to decode\"\n}  \n\nreturn msg;","outputs":1,"noerr":0,"x":394.5555419921875,"y":279.5555725097656,"wires":[["22cb3401.ef7e24","2d12c5a2.7304aa","fd30fa09.244ce8"]]}]
Created 10 years, 11 months ago
Updated 7 years, 11 months ago
  • MySensors
  • decode
