Art-Net sending and receiving
Art-Net encoder/decoder
This sublow is a bi-directional Art-Net encoder/decoder.
Receiving
Connect a udp in object set to port 6454 to the input of the subflow.
The Art-Net data will be output as msg.payload in Buffer form.
The universe is available as msg.topic.
Sending
Send an Array or Buffer to the Art-Net subflow and connect the sublow's output to a udp out object set to port 6454. The universe must be set as msg.topic.
[{"id":"3ba422b0.9c410e","type":"subflow","name":"Artnet","info":"# Art-Net encoder/decoder\n\nThis sublow is a bi-directional Art-Net encoder/decoder.\n\n## Receiving\n\nConnect a `udp in` object set to port *6454* to the input of the subflow.  \nThe Art-Net data will be output as `msg.payload` in Buffer form.  \nThe universe is available as `msg.topic`.\n\n## Sending\n\nSend an `Array` or `Buffer` to the Art-Net subflow and connect the sublow's output to a `udp out` object set to port *6454*.\nThe universe must be set as `msg.topic`.","in":[{"x":180,"y":140,"wires":[{"id":"54870efc.1f38e8"}]}],"out":[{"x":440,"y":140,"wires":[{"id":"54870efc.1f38e8","port":0}]}]},{"id":"54870efc.1f38e8","type":"function","z":"3ba422b0.9c410e","name":"Artnet","func":"const HEADER_SIZE = 18;\nconst ID = \"Art-Net\\0\";\nconst ArtDmxOpCode = 0x5000;\nconst ProtVer = 14;\ncontext.sequence = context.sequence || 0;\nconst Physical = 0;\n\nvar header = new Buffer(HEADER_SIZE);\nheader.fill(0);\n\nheader.write(ID);\nheader.writeUInt16LE(ArtDmxOpCode, 8);\nheader.writeUInt16BE(ProtVer, 10);\nheader.writeUInt8(Physical, 13);\n\n// Parse incoming Art-Net packets\nif (msg.payload.slice(0, 8).toString() == ID) {\n    var Opcode = msg.payload.readUInt16LE(8);\n    if (Opcode == ArtDmxOpCode) {\n        var Universe = msg.payload.readUInt16LE(14);\n        var Length = msg.payload.readUInt16BE(16);\n        msg.topic = Universe;\n        msg.payload = msg.payload.slice(HEADER_SIZE, Length + HEADER_SIZE);\n        node.send(msg);\n    }\n// Format incoming buffer or array into Art-Net packet\n} else {\n    context.sequence++;\n    header.writeUInt8(context.sequence, 12);\n    if (context.sequence >= 255)\n        context.sequence = 0;\n    \n    var Universe = msg.topic;\n    var Length = msg.payload.length;\n    if (Array.isArray(msg.payload)) {\n        msg.payload = new Buffer(msg.payload);\n    }\n    header.writeUInt16LE(Universe, 14);\n    header.writeUInt16BE(Length, 16);\n    \n    msg.payload = Buffer.concat([header, msg.payload]);\n    node.send(msg);\n}\n\n\n","outputs":1,"noerr":0,"x":310,"y":140,"wires":[[]]},{"id":"d53116db.4e6448","type":"udp in","z":"52b800eb.285ab8","name":"","iface":"","port":"6454","ipv":"udp4","multicast":"false","group":"","datatype":"buffer","x":140,"y":140,"wires":[["8ae18555.173a08"]]},{"id":"bf51a0e4.9141c8","type":"inject","z":"52b800eb.285ab8","name":"","topic":"1","payload":"[255,255,255,255,255]","payloadType":"json","repeat":"","crontab":"","once":false,"x":190,"y":280,"wires":[["60275d4c.9b60dc"]]},{"id":"ed7aa2c1.abe42","type":"debug","z":"52b800eb.285ab8","name":"","active":true,"console":"false","complete":"false","x":510,"y":140,"wires":[]},{"id":"87528ebd.ee762","type":"comment","z":"52b800eb.285ab8","name":"Receive","info":"","x":130,"y":100,"wires":[]},{"id":"8ae18555.173a08","type":"subflow:3ba422b0.9c410e","z":"52b800eb.285ab8","name":"","x":310,"y":140,"wires":[["ed7aa2c1.abe42"]]},{"id":"27a65618.ee047a","type":"udp out","z":"52b800eb.285ab8","name":"","addr":"localhost","iface":"","port":"6454","ipv":"udp4","outport":"","base64":false,"multicast":"false","x":660,"y":280,"wires":[]},{"id":"60275d4c.9b60dc","type":"subflow:3ba422b0.9c410e","z":"52b800eb.285ab8","name":"","x":430,"y":280,"wires":[["27a65618.ee047a"]]},{"id":"2c150c62.865b04","type":"comment","z":"52b800eb.285ab8","name":"Send","info":"","x":130,"y":240,"wires":[]},{"id":"d3233035.bedfe8","type":"comment","z":"52b800eb.285ab8","name":"Art-Net sending and receiving","info":"","x":200,"y":40,"wires":[]}]
Created 8 years, 1 month ago
Updated 4 years, 5 months ago
Rating: 5 1
  • comment (x3)
  • udp in (x1)
  • udp out (x1)
  • subflow (x1)
  • subflow:3ba422b0.9c410e (x2)
  • artnet
  • Art-Net
  • dmx
