Smick_002_LED_dgital_v3
This flow builds a dashboard that contains a switch node to switch on or off the LED. The generated commands are sent to Smick through "dasboard console" flow".
        "id": "e192fa90.cfab68",
        "type": "ui_switch",
        "z": "5ce9b4ba.37af7c",
        "label": "Off/On",
        "group": "5e36b7c5.bef018",
        "order": 1,
        "width": 0,
        "height": 0,
        "passthru": false,
        "topic": "",
        "style": "",
        "onvalue": "d8=0",
        "onvalueType": "str",
        "onicon": "",
        "oncolor": "",
        "offvalue": "d8=1",
        "offvalueType": "str",
        "officon": "",
        "offcolor": "",
        "x": 150,
        "y": 260,
                "76792d1c.717924"
        "id": "76792d1c.717924",
        "type": "link out",
        "name": "command",
        "links": [
            "d00f3010.4b85b"
        "x": 375,
        "y": 260,
        "id": "bf91673.1e8b498",
        "type": "comment",
        "name": "digital output",
        "info": "",
        "x": 150,
        "y": 160,
        "id": "dfbe47e2.b63df8",
        "type": "comment",
        "name": "Description",
        "info": "Smick_002_LED_dgital\n_______________________________________________________________________________\nPackage : Smick v.1\nModule  : console\nAuthor  : Curci\nLicence : (CC) BY-NC-SA\n\nThis work is licensed under a Creative Commons \nAttribution-NonCommercial-ShareAlike \n4.0 International License.\n\nHistory\n\nDate        Author  Description\n2016.12.17  Curci   genesis\n_______________________________________________________________________________\n\nDescription\n\nQuesto flusso costruisce un cruscotto contenente un nodo switch per accendere o spegnere il LED.\nI comandi generati sono inviati a smick tramite il flusso \"dasboard console\".\n\nThis flow builds a dashboard that contains a switch node to switch on or off the LED.\nThe generated commands are sent to Smick through \"dasboard console\" flow\".\n_______________________________________________________________________________\n\nBill Of Material\n\nHardware:\n\n    1 Human internet terminal (PC, tablet or smartphone) connected to the internet\n    1 Smick Wi-Fi connected to the internet\n    1 LED connected to smick \n\nHW Connections:\n\n    Device  pin     Smick pin\n    LED     +       3.3V\n    LED     -       D8\n\nFlow Connections:\n\n    Smick_001_console\n\nAccount:\n\n    Wi-Fi credentials\n    MQTT broker\n    FRED\n",
        "x": 140,
        "y": 100,
        "id": "5e36b7c5.bef018",
        "type": "ui_group",
        "z": "",
        "name": "LED",
        "tab": "9f185bbc.98cc78",
        "order": 1,
        "disp": true,
        "width": "6"
        "id": "9f185bbc.98cc78",
        "type": "ui_tab",
        "z": "",
        "name": "LED",
        "icon": "dashboard",
        "order": 2
infosmick
created 3 months, 1 week ago
  • comment (x2)
  • link out (x1)
  • ui_group (x1)
  • ui_switch (x1)
  • Smick
  • iot
