Watson Speech to Text websocket API
This sample application demonstrates Watson Speech to Text (STT) in websocket mode. Transcript of voice recording can be shown in stream fashion by both standard STT and custom STT (trained by you). It also shows timestamp and Confidence of each sentences.
[{"id":"f75ab2a.2f3815","type":"http in","z":"84a189af.1120f8","name":"","url":"/std","method":"get","swaggerDoc":"","x":86,"y":113.00001525878906,"wires":[["61253d51.bbdf54"]]},{"id":"81e255d8.0c7aa8","type":"http response","z":"84a189af.1120f8","name":"","x":722.0001678466797,"y":111.00001525878906,"wires":[]},{"id":"a3076265.819cf8","type":"http request","z":"84a189af.1120f8","name":"get Custom STT Token","method":"GET","ret":"txt","url":"https://stream.watsonplatform.net/authorization/api/v1/customizations/e161d8f0-0578-11e7-94ad-3b2269260fbc/token?url=https://stream.watsonplatform.net/speech-to-text/api","tls":"","x":289.4999542236328,"y":214.04039001464844,"wires":[["5612f29a.dacfdc"]]},{"id":"aabf7100.ee42c8","type":"debug","z":"84a189af.1120f8","name":"","active":false,"console":"true","complete":"true","x":720.5001068115234,"y":213.1323699951172,"wires":[]},{"id":"61253d51.bbdf54","type":"http request","z":"84a189af.1120f8","name":"get Standard STT Token","method":"GET","ret":"txt","url":"https://stream.watsonplatform.net/authorization/api/v1/token?url=https://stream.watsonplatform.net/speech-to-text/api","tls":"","x":294.99998474121094,"y":113,"wires":[["d5e7c6e3.1a87a"]]},{"id":"d5e7c6e3.1a87a","type":"template","z":"84a189af.1120f8","name":"Standard Watson STT","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"<html>\n<head>\n    <script type=\"text/javascript\">\n    var token = \"{{payload}}\";\n    var model = \"ja-JP_NarrowbandModel\";  // Change to your own model\n    var wsURI = 'wss://stream.watsonplatform.net/speech-to-text/api/v1/recognize?watson-token=' +\n                token + '&model=' + model;\n    var message = { 'action': 'start',\n                'content-type': 'audio/wav',\n                'continuous': true,\n                'interim_results': true,\n                'inactivity_timeout': 6000,\n                'word_confidence': false,\n                'timestamps': true,\n                'max_alternatives': 0,\n                'keywords': ['imposible', 'unavailable'],\n                'keywords_threshold': 0.8,\n                'speaker_labels': true\n     };\n\tvar message2 = {'action': 'stop'};\n\tvar index = 0;\n\tvar ws = new WebSocket(wsURI);\n    ws.onopen = function(evt) { onOpen(evt) };\n    ws.onmessage = function(evt) { onMessage(evt) };\n    ws.onclose = function(evt) { onClose(evt) };\n    ws.onerror = function(evt) { onError(evt) };\n\nfunction sendMessage() {\n    console.log(\"sendMessae\");\n    var file = parent.frame1.document.getElementById('file_input').files[0];\n\tvar reader = new FileReader();\n    reader.onload = function () {\n        ws.send(reader.result);\n    };\n    reader.readAsArrayBuffer(file);\n};\n\nfunction onOpen(evt) {\n    fileselection();\n    console.log(\"onOpen:\"+JSON.stringify(message));\n    ws.send(JSON.stringify(message));\n};\n\nfunction onClose(evt) {\n    console.log(\"onClose:\"+evt.code+evt.reason);\n    ws.close();\n};\n\nfunction onMessage(evt) {\n  var object = JSON.parse(evt.data);\n   console.log(\"onMessage:\"+evt.data);\n    if ( evt.data.indexOf(\"results\") >= 1) {\n        if (object[\"results\"][0][\"final\"] == true) {\n            printout(\n                object[\"results\"][0][\"alternatives\"][0][\"timestamps\"][0][2],\n                object[\"results\"][0][\"alternatives\"][0][\"confidence\"],\n                object[\"results\"][0][\"alternatives\"][0][\"transcript\"],\n                object[\"result_index\"]\n            );\n        };\n    };\n};\nfunction onError(evt) {\n    console.log(\"onError:\"+evt.data);\n};\n\nfunction disconnect() {\n    ws.send(JSON.stringify(message2));\n    console.log(\"disconnect\");\n    ws.close();\n};\n\nfunction printout(time,confidence,text,i){\n\tparent.frame2.document.write(\n\t    \"<div style=\\\"text-align:left\\\" >\"\n\t    +i\n\t    +\" (\"+time+\") [\"\n\t    +Math.round(confidence*1000)/10+\"%]\"\n\t    +text+\n\t    \"</div><p></p>\");\n};\n\nfunction fileselection(){\n    parent.frame1.document.open();\n    parent.frame1.document.write('<h1>Standard Watson STT Websocket Sample Application</h1>\\n');\n    parent.frame1.document.write('<form>\\n');\n    parent.frame1.document.write('<input type=\"file\" id=\"file_input\" onchange=\"parent.sendMessage()\">\\n');\n    parent.frame1.document.write('<div><button onclick=\"parent.disconnect()\">Disconnect</button></div>\\n');\n    parent.frame2.document.close();\n};\n\n</script>\n</head>\n<frameset cols=\"300,*\">\n<frame src=\"\" name=\"frame1\">\n<frame src=\"\" name=\"frame2\">\n</frameset>\n</html>\n","x":529.0000152587891,"y":112,"wires":[["81e255d8.0c7aa8","aabf7100.ee42c8"]]},{"id":"8ca5d2ce.6b7108","type":"http in","z":"84a189af.1120f8","name":"","url":"/custom","method":"get","swaggerDoc":"","x":94.99998474121094,"y":215,"wires":[["a3076265.819cf8"]]},{"id":"2d269014.98709","type":"comment","z":"84a189af.1120f8","name":"Trigger","info":"","x":88.48893737792969,"y":50.040435791015625,"wires":[]},{"id":"787f6f2.e01389","type":"comment","z":"84a189af.1120f8","name":"Transcription","info":"","x":518.4962921142578,"y":47.04779052734375,"wires":[]},{"id":"61b9517d.3c42f","type":"comment","z":"84a189af.1120f8","name":"output","info":"","x":705.4852752685547,"y":48.04779052734375,"wires":[]},{"id":"d1ce740c.b657d8","type":"comment","z":"84a189af.1120f8","name":"Authentication","info":"","x":279.99998474121094,"y":47,"wires":[]},{"id":"5612f29a.dacfdc","type":"template","z":"84a189af.1120f8","name":"Standard Watson STT","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"<html>\n<head>\n    <script type=\"text/javascript\">\n    var token = \"{{payload}}\";\n    var customid = \"e161d8f0-0578-11e7-94ad-3b2269260fbc\"; //Change to your own customid\n    var model = \"ja-JP_NarrowbandModel\"; //Cange to your own model\n    var wsURI = 'wss://stream.watsonplatform.net/speech-to-text/api/v1/recognize?watson-token=' +\n                token + '&customization_id=' + customid + '&model=' + model;\n    var message = { 'action': 'start',\n                'content-type': 'audio/wav',\n                'continuous': true,\n                'interim_results': true,\n                'inactivity_timeout': 6000,\n                'word_confidence': false,\n                'timestamps': false,\n                'max_alternatives': 0,\n                'keywords': ['できません', '不可能'], //Change to your own keywords\n                'keywords_threshold': 0.8,\n                'speaker_labels': true\n     };\n     \n\tvar message2 = {'action': 'stop'};\n\tvar index = 0;\n\tvar ws = new WebSocket(wsURI);\n    ws.onopen = function(evt) { onOpen(evt) };\n    ws.onmessage = function(evt) { onMessage(evt) };\n    ws.onclose = function(evt) { onClose(evt) };\n    ws.onerror = function(evt) { onError(evt) };\n\nfunction sendMessage() {\n    console.log(\"sendMessae\");\n    var file = parent.frame1.document.getElementById('file_input').files[0];\n\tvar reader = new FileReader();\n    reader.onload = function () {\n        ws.send(reader.result);\n    };\n    reader.readAsArrayBuffer(file);\n};\n\nfunction onOpen(evt) {\n    fileselection();\n    console.log(\"onOpen:\"+JSON.stringify(message));\n    ws.send(JSON.stringify(message));\n};\n\nfunction onClose(evt) {\n    console.log(\"onClose:\"+evt.code+evt.reason);\n    ws.close();\n};\n\nfunction onMessage(evt) {\n  var object = JSON.parse(evt.data);\n   console.log(\"onMessage:\"+evt.data);\n    if ( evt.data.indexOf(\"results\") >= 1) {\n        if (object[\"results\"][0][\"final\"] == true) {\n            printout(\n                object[\"results\"][0][\"alternatives\"][0][\"timestamps\"][0][2],\n                object[\"results\"][0][\"alternatives\"][0][\"confidence\"],\n                object[\"results\"][0][\"alternatives\"][0][\"transcript\"],\n                object[\"result_index\"]\n            );\n        };\n    };\n};\nfunction onError(evt) {\n    console.log(\"onError:\"+evt.data);\n};\n\nfunction disconnect() {\n    ws.send(JSON.stringify(message2));\n    console.log(\"disconnect\");\n    ws.close();\n};\n\nfunction printout(time,confidence,text,i){\n\tparent.frame2.document.write(\n\t    \"<div style=\\\"text-align:left\\\" >\"\n\t    +i\n\t    +\" (\"+time+\") [\"\n\t    +Math.round(confidence*1000)/10+\"%]\"\n\t    +text+\n\t    \"</div><p></p>\");\n};\n\nfunction fileselection(){\n    parent.frame1.document.open();\n    parent.frame1.document.write('<h1>Custom Watson STT Websocket Sample Application</h1>\\n');\n    parent.frame1.document.write('<form>\\n');\n    parent.frame1.document.write('<input type=\"file\" id=\"file_input\" onchange=\"parent.sendMessage()\">\\n');\n    parent.frame1.document.write('<div><button onclick=\"parent.disconnect()\">Disconnect</button></div>\\n');\n    parent.frame2.document.close();\n};\n\n</script>\n</head>\n<frameset cols=\"300,*\">\n<frame src=\"\" name=\"frame1\">\n<frame src=\"\" name=\"frame2\">\n</frameset>\n</html>\n","x":532,"y":214,"wires":[["81e255d8.0c7aa8","aabf7100.ee42c8"]]}]
Created 7 years, 8 months ago
Updated 7 years, 1 month ago
  • comment (x4)
  • http in (x2)
  • http request (x2)
  • http response (x1)
  • template (x2)
