Pololu DRV8835 2ch PWM DC Motor Controller (Raspberry Pi)
Flow to allow control of a pair of DC motors connected to Pololu DRV8835 (https://www.pololu.com/product/2753) on Raspberry Pi via node-red-contrib-ui / node-red-dashboard
Requires wiring-pi to be installed as a node_module within node-red folder and added to global context via settings.js (see “wiring-pi module” section at http://nodered.org/docs/hardware/raspberrypi)
[{"id":"79ea8e00.7cd484","type":"ui_slider","z":"a7216b4a.a1fcd","tab":"9cfc2f36.2694a8","name":"Speed","topic":"m1","group":"Motor 1","order":1,"min":0,"max":"480","x":810,"y":260,"wires":[["b481c365.4a42f","3dc20b3e.fe5d14"]]},{"id":"f889fc69.10b538","type":"ui_slider","z":"a7216b4a.a1fcd","tab":"9cfc2f36.2694a8","name":"Speed","topic":"m2","group":"Motor 2","order":1,"min":0,"max":"480","x":810,"y":400,"wires":[["a03df7dc.38827","dde030f6.7ad65"]]},{"id":"647df633.d2cba","type":"ui_switch","z":"a7216b4a.a1fcd","tab":"9cfc2f36.2694a8","name":"Direction","topic":"","group":"Motor 1","order":1,"onvalue":"1","offvalue":"0","x":280,"y":300,"wires":[["2edc04b.5fa487c"]]},{"id":"45b2b096.767608","type":"ui_switch","z":"a7216b4a.a1fcd","tab":"9cfc2f36.2694a8","name":"Direction","topic":"","group":"Motor 2","order":1,"onvalue":"1","offvalue":"0","x":280,"y":440,"wires":[["ef9e9962.a8354"]]},{"id":"2edc04b.5fa487c","type":"rpi-gpio out","z":"a7216b4a.a1fcd","name":"Motor 1 Direction","pin":"29","set":true,"level":"1","out":"out","x":1090,"y":300,"wires":[]},{"id":"ef9e9962.a8354","type":"rpi-gpio out","z":"a7216b4a.a1fcd","name":"Motor 2 Direction","pin":"31","set":true,"level":"1","out":"out","x":1090,"y":440,"wires":[]},{"id":"c4ce2cdb.917fa","type":"inject","z":"a7216b4a.a1fcd","name":"Init 1","topic":"","payload":"1","payloadType":"num","repeat":"","crontab":"","once":true,"x":90,"y":380,"wires":[["45b2b096.767608","647df633.d2cba","fb5ed58c.1458d8","f800ca94.eb7e"]]},{"id":"b481c365.4a42f","type":"function","z":"a7216b4a.a1fcd","name":"Motor 1 Speed","func":"var pin = 26;\nvar wpi = context.global.wpi;\nwpi.wiringPiSetup();\nwpi.pinMode(pin, wpi.PWM_OUTPUT);\nwpi.pwmSetMode(wpi.PWM_MODE_MS);\nwpi.pwmSetRange(480);\nwpi.pwmSetClock(2);\nif(msg.payload){\n    wpi.pwmWrite(pin, parseInt(msg.payload));\n} else {\n    wpi.pwmWrite(pin, 0);\n}\nreturn msg;","outputs":1,"noerr":0,"x":1080,"y":260,"wires":[[]]},{"id":"a03df7dc.38827","type":"function","z":"a7216b4a.a1fcd","name":"Motor 2 Speed","func":"var pin2 = 23;\nvar wpi = context.global.wpi;\nwpi.wiringPiSetup();\nwpi.pinMode(pin2, wpi.PWM_OUTPUT);\nwpi.pwmSetMode(wpi.PWM_MODE_MS);\nwpi.pwmSetRange(480);\nwpi.pwmSetClock(2);\nif(msg.payload){\n    wpi.pwmWrite(pin2, parseInt(msg.payload));\n} else {\n    wpi.pwmWrite(pin2, 0);\n}\nreturn msg;","outputs":1,"noerr":0,"x":1080,"y":400,"wires":[[]]},{"id":"dde030f6.7ad65","type":"ui_chart","z":"a7216b4a.a1fcd","tab":"9cfc2f36.2694a8","name":"Motor 2 (Y / Alt / DEC)","group":"History","order":1,"interpolate":"basis","nodata":"No Data","removeOlder":1,"removeOlderUnit":"60","x":1100,"y":360,"wires":[[],[]]},{"id":"3dc20b3e.fe5d14","type":"ui_chart","z":"a7216b4a.a1fcd","tab":"9cfc2f36.2694a8","name":"Motor 1 (X / Az / RA)","group":"History","order":1,"interpolate":"basis","nodata":"No Data","removeOlder":1,"removeOlderUnit":"60","x":1100,"y":220,"wires":[[],[]]},{"id":"9cfc2f36.2694a8","type":"ui_tab","z":"","name":"Home","icon":"dashboard","order":"1"}]
Created 10 years, 7 months ago
  • function (x2)
  • rpi-gpio out (x2)
  • ui_chart (x2)
  • ui_slider (x2)
  • ui_switch (x2)
  • pololu
  • motor
  • drv8835
  • raspberry
