4Factory
This flow is to summarize IoT connections from CLP/ebox to AWS IoT Hub.
[{"id":"7add9f95.36737","type":"mqtt-broker","z":"","broker":"15.1.4.50","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willRetain":null,"willPayload":"","birthTopic":"","birthQos":"0","birthRetain":null,"birthPayload":""},{"id":"d814ac59.51db5","type":"debug","z":"828b7952.cf43c8","name":"","active":true,"console":"false","complete":"true","x":585,"y":324,"wires":[]},{"id":"31036645.e9fe8a","type":"mqtt in","z":"828b7952.cf43c8","name":"Peets Button","topic":"dashbutton/peets","broker":"7add9f95.36737","x":124.5,"y":325,"wires":[["d814ac59.51db5","1a8e95fc.25de7a"]]},{"id":"1a8e95fc.25de7a","type":"function","z":"828b7952.cf43c8","name":"Set Peets Variable","func":"node.warn('start');\nif (!context.global.state) {\n node.warn('context.global.state is null');\n context.global.state = { peets: false };\n if (context.global.state.peets === null) {\n node.warn('context.global.state.peets is null');\n context.global.state.peets = false;\n }\n}\nif (context.global.state && context.global.state.peets) {\n node.warn('toggle state');\n context.global.state.peets = !context.global.state.peets;\n} else {\n node.warn('setting state to true');\n context.global.state.peets = true;\n}\n node.warn('sending msg: ' + context.global.state.peets);\n return context.global.state.peets;","outputs":1,"noerr":0,"x":365.5,"y":383,"wires":[["d814ac59.51db5"]]}]
