Fritz!Box Call Monitor
This is a simple flow that gets informations from Fritz!Box built-in Call Monitor and get them in node-red. Host is specified with the name fritz.box
that resolves to the fritz!box router itself, or you can specify another ip address as you like.
Prerequisites
- Enable built-in Call Monitor on your Fritz!Box by dialing
#96*5*
This enables access to the built-in Call monitor that is exposed on tcp port 1012.
If you no longer need it, you can later disable the call monitor by dialing #96*4*
for further info and complete list of codes see: http://www.wehavemorefun.de/fritzbox/Tastencodes (link is in german)
[{"id":"4d6d479.784e4b8","type":"debug","z":"a2ac8504.92ff08","name":"","active":true,"console":"false","complete":"payload","x":1310,"y":720,"wires":[]},{"id":"c36d144.8baade8","type":"template","z":"a2ac8504.92ff08","name":"Incoming","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Incoming call from: {{payload.col4}}","x":1140,"y":780,"wires":[["4d6d479.784e4b8","1631abff.b8d824"]]},{"id":"905d4bf.64e80b8","type":"switch","z":"a2ac8504.92ff08","name":"","property":"payload.col2","propertyType":"msg","rules":[{"t":"eq","v":"RING","vt":"str"},{"t":"eq","v":"DISCONNECT","vt":"str"}],"checkall":"true","outputs":2,"x":990,"y":800,"wires":[["c36d144.8baade8"],[]]},{"id":"bcba416f.0aba1","type":"csv","z":"a2ac8504.92ff08","name":"","sep":";","hdrin":"","hdrout":"","multi":"one","ret":"\\n","temp":"","x":870,"y":800,"wires":[["905d4bf.64e80b8"]]},{"id":"513989a1.4de1d8","type":"tcp in","z":"a2ac8504.92ff08","name":"","server":"client","host":"fritz.box","port":"1012","datamode":"stream","datatype":"utf8","newline":"","topic":"","base64":false,"x":700,"y":800,"wires":[["bcba416f.0aba1"]]}]
