Arduino Serial - Node-RED - ioBroker
This Node-RED flow is between the serial connected Adruino UNO via USB port and the ioBroker. For this example are 2 switches und 2 relays on Arduino digital GPIOs connected. The Arduino is also working stand alone. Node-RED is listing on the Arduino’s serial monitor and send the data to ioBroker. Also ioBroker is sending commands to Node-RED and Node-RED do an forward to the Arduino’s serial monitor. The Sketch for the Arduino you can copy from https://www.4hf.de/raspberry-pi/iobroker-node-red-raspberry-serial-arduino-heimautomation-209.htm
[{"id":"5dc14f5e.b39e48","type":"tab","label":"Relais01"},{"id":"87b2cdb9.c9cc38","type":"serial in","z":"5dc14f5e.b39e48","name":"Arduino USB","serial":"413a9322.7df064","x":105,"y":182,"wires":[["61d2de74.9707c","42e8d89e.b7faf8"]]},{"id":"5a5f5efe.415708","type":"debug","z":"5dc14f5e.b39e48","name":"","active":true,"console":"false","complete":"payload","x":632,"y":455,"wires":[]},{"id":"2f9387d6.cb62c","type":"serial out","z":"5dc14f5e.b39e48","name":"Arduino USB","serial":"413a9322.7df064","x":602,"y":178,"wires":[]},{"id":"553740d1.71b318","type":"ui_switch","z":"5dc14f5e.b39e48","name":"","label":"Relais01 Schalter","group":"9c90b407.f62ef","order":0,"width":0,"height":0,"passthru":true,"topic":"","style":"","onvalue":"C","onvalueType":"str","onicon":"","oncolor":"","offvalue":"D","offvalueType":"str","officon":"","offcolor":"","x":415,"y":142,"wires":[["2f9387d6.cb62c"]]},{"id":"11f1c6bf.cd6291","type":"ioBroker out","z":"5dc14f5e.b39e48","name":"Staus Lampe","topic":"Status Lampe","ack":"true","autoCreate":"true","x":582,"y":620,"wires":[]},{"id":"33cdc360.cd1dac","type":"change","z":"5dc14f5e.b39e48","name":"Relais1","rules":[{"t":"change","p":"payload","pt":"msg","from":"Relais3:0","fromt":"str","to":"0","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Relais3:1","fromt":"str","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":355,"y":620,"wires":[["11f1c6bf.cd6291","5a5f5efe.415708"]]},{"id":"c1b0897b.6bf018","type":"change","z":"5dc14f5e.b39e48","name":"Relais2","rules":[{"t":"change","p":"payload","pt":"msg","from":"Relais4:0","fromt":"str","to":"0","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Relais4:1","fromt":"str","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":281,"y":444,"wires":[["60d1c07b.a0b2d","5213599c.e25638","5a5f5efe.415708"]]},{"id":"60d1c07b.a0b2d","type":"ioBroker out","z":"5dc14f5e.b39e48","name":"Status Lampe02","topic":"Status Lampe02","ack":"true","autoCreate":"true","x":492,"y":385,"wires":[]},{"id":"61d2de74.9707c","type":"switch","z":"5dc14f5e.b39e48","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Relais3:0","vt":"str"},{"t":"cont","v":"Relais3:1","vt":"str"}],"checkall":"true","outputs":2,"x":181,"y":619,"wires":[["33cdc360.cd1dac"],["33cdc360.cd1dac"]]},{"id":"42e8d89e.b7faf8","type":"switch","z":"5dc14f5e.b39e48","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Relais4:0","vt":"str"},{"t":"cont","v":"Relais4:1","vt":"str"}],"checkall":"true","outputs":2,"x":303,"y":323,"wires":[["c1b0897b.6bf018"],["c1b0897b.6bf018"]]},{"id":"2a0b5d9e.adbf0a","type":"ui_colour_picker","z":"5dc14f5e.b39e48","name":"","label":"","group":"9c90b407.f62ef","format":"hex","outformat":"string","showSwatch":true,"showPicker":false,"showValue":false,"showAlpha":false,"showLightness":true,"order":0,"width":"2","height":"2","passthru":true,"topic":"","x":662,"y":540,"wires":[[]]},{"id":"5213599c.e25638","type":"change","z":"5dc14f5e.b39e48","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"0","fromt":"num","to":"red","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"str","to":"green","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":403,"y":538,"wires":[["2a0b5d9e.adbf0a"]]},{"id":"c1a493a4.35a2a","type":"ioBroker in","z":"5dc14f5e.b39e48","name":"Von ioBroker","topic":"Von ioBroker","payloadType":"value","onlyack":false,"func":"all","gap":"","x":426,"y":228,"wires":[["2f9387d6.cb62c"]]},{"id":"413a9322.7df064","type":"serial-port","z":"","serialport":"/dev/ttyACM0","serialbaud":"9600","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":false},{"id":"9c90b407.f62ef","type":"ui_group","z":"","name":"Schalter01","tab":"df8d25f2.4868c8","disp":true,"width":"6"},{"id":"df8d25f2.4868c8","type":"ui_tab","z":"","name":"Schalter","icon":"dashboard"}]
Created 10 years, 3 months ago
  • change (x3)
  • switch (x2)
  • ioBroker in (x1)
  • ioBroker out (x2)
  • serial in (x1)
  • serial out (x1)
  • serial-port (x1)
  • ui_colour_picker (x1)
  • ui_group (x1)
  • ui_switch (x1)
  • ioBroker
  • Arduino
  • Serial
