Ivona flow 2
This flow is for windows. To make it work, you need to
- Download Videolan's VLC player
- Install the IVONA node.
You will find that the audio files created by IVONA are stored in your user directory (e.g. C:\Users*your user id* and this is a great feature of the IVONA node, because these files are re-used if present.
N.B. If you use a sound effect MP3 for "amy--alert.mp3", it will be played before the speech
[{"id":"c3e3d8a.4c839a8","type":"ivona-credentials","z":"","name":"ivona","api_key":"GDNAIZON36CJ3Z2LPLWQ","password":"sxpMBamnL1bpKf/epIcP/qF/40m2mibFiNs430R4"},{"id":"2bb6dd4d.406e4a","type":"ivona-tts","z":"a81c5622.38e608","name":"","message":"{{payload}}","voice":"8","exec":"\"C:\\Program Files (x86)\\VideoLAN\\VLC\\vlc.exe\" --one-instance --intf dummy {{{file}}}","dir":"{{voice_name}}-{{lang}}-{{slug}}.mp3","broker":"c3e3d8a.4c839a8","x":584,"y":736,"wires":[[]]},{"id":"c3879532.278af8","type":"inject","z":"a81c5622.38e608","name":"","topic":"","payload":"I am a computer","payloadType":"str","repeat":"","crontab":"","once":false,"x":150,"y":730.5,"wires":[["28c46dbd.4166ba"]]},{"id":"3c99ce79.738532","type":"inject","z":"a81c5622.38e608","name":"","topic":"","payload":"can you dig it?","payloadType":"str","repeat":"","crontab":"","once":false,"x":149,"y":772,"wires":[["28c46dbd.4166ba"]]},{"id":"dfa44dc1.21cac8","type":"inject","z":"a81c5622.38e608","name":"","topic":"alert","payload":"Attention humans","payloadType":"str","repeat":"","crontab":"","once":false,"x":173,"y":689,"wires":[["28c46dbd.4166ba"]]},{"id":"28c46dbd.4166ba","type":"function","z":"a81c5622.38e608","name":"","func":"if (msg.topic!==\"\")\n {\n var msg1 = { payload : msg.topic };\n return [ [ msg1, msg ]];\n }\nelse \n {\nreturn msg; \n}","outputs":"1","noerr":0,"x":369,"y":736.5,"wires":[["2bb6dd4d.406e4a","23221156.7ba096"]]},{"id":"23221156.7ba096","type":"debug","z":"a81c5622.38e608","name":"","active":true,"console":"false","complete":"false","x":608,"y":668,"wires":[]}]
