Simple Modscan like UI for Modbus testing
This flow creates a Tab "Modscan" in Node-Red UI that allows to:
- Manual SERIAL and TCP connection (NEW FEATURE)
- Read Modscan Registers And Coils in real time (FC3 and FC1)
- Convert 2*16bit registers in 32 bit
- Convert values in HEX rappresentation
- Convert values in Float IEEE-754 rappresentation
- Write Registers and Coils (FC5 FC6)
- Write Hex values (The hex value will be converted to int than sent to Modbus Write Node)
THIS FLOW HAS BEEN EDITED TO WORK WITH LAST NODE-RED-CONTRIB-MODBUS VERSION AT THIS DATE (2.3.2). TO MAKE IT WORK WITH OLDER/FUTURE VERSIONS OF MODBUS CHECK THE OUTPUT OF MODBUS FLEX READ AND USE THE CHANGE NODE TO MOVE READED DATA INTO msg.payload. ATM the payload of modbus-flex-read has 2 fileds: 'buffer' and 'data' so the change node is used to move msg.payload.data into msg.payload.
[{"id":"3007b84d.585828","type":"tab","label":"MODSCAN ","disabled":false,"info":""},{"id":"32802fb2.df634","type":"inject","z":"3007b84d.585828","name":"","topic":"","payload":"","payloadType":"date","repeat":"0.5","crontab":"","once":false,"onceDelay":"","x":127.1429443359375,"y":683.8571310043335,"wires":[["9dcffcba.11e58"]]},{"id":"9dcffcba.11e58","type":"function","z":"3007b84d.585828","name":"enable","func":"if(flow.get(\"enabled\")){\n flow.set(\"count\", flow.get(\"count\") + 1);\n msg.payload = {'fc': flow.get(\"FC\"), 'unitid': flow.get(\"unitid\"), 'address': flow.get(\"address\") , 'quantity': flow.get(\"length\"), 'conversion': flow.get(\"conversion\") };\n}else\n msg = null;\n \nreturn msg;","outputs":1,"noerr":0,"x":309.1429443359375,"y":683.8571310043335,"wires":[["85dd1b59.3dac48"]]},{"id":"fc92b2a7.bdd9a","type":"ui_button","z":"3007b84d.585828","name":"","group":"426c6703.2c1038","order":8,"width":"3","height":"1","passthru":false,"label":"Start","color":"","bgcolor":"","icon":"","payload":"1","payloadType":"num","topic":"","x":429.6429443359375,"y":861.8571310043335,"wires":[["7cc0168.d03e0e8"]]},{"id":"7cc0168.d03e0e8","type":"function","z":"3007b84d.585828","name":"enable","func":"flow.set(\"enabled\", true);\nflow.set(\"count\", 0);","outputs":"0","noerr":0,"x":598.1429443359375,"y":861.8571310043335,"wires":[]},{"id":"4d70ca37.fe1dc4","type":"ui_button","z":"3007b84d.585828","name":"","group":"426c6703.2c1038","order":9,"width":"3","height":"1","passthru":false,"label":"Stop","color":"","bgcolor":"","icon":"","payload":"1","payloadType":"num","topic":"","x":429.1429443359375,"y":912.8571310043335,"wires":[["7196f276.e2a1dc"]]},{"id":"7196f276.e2a1dc","type":"function","z":"3007b84d.585828","name":"disable","func":"flow.set(\"enabled\", false);","outputs":"0","noerr":0,"x":605.6429443359375,"y":912.8571310043335,"wires":[]},{"id":"5250a8de.1acd38","type":"function","z":"3007b84d.585828","name":"save","func":"flow.set(\"address\", msg.payload);","outputs":"0","noerr":0,"x":595.1429443359375,"y":955.8571310043335,"wires":[]},{"id":"dd349bfe.086ca8","type":"function","z":"3007b84d.585828","name":"save","func":"flow.set(\"length\", msg.payload);","outputs":"0","noerr":0,"x":596.1429443359375,"y":1000.8571310043335,"wires":[]},{"id":"f48850f7.e3c05","type":"function","z":"3007b84d.585828","name":"save","func":"flow.set(\"FC\", msg.payload);","outputs":"0","noerr":0,"x":593.1429443359375,"y":1043.8571310043335,"wires":[]},{"id":"85dd1b59.3dac48","type":"modbus-flex-getter","z":"3007b84d.585828","name":"read","showStatusActivities":false,"showErrors":false,"server":"5876d9d3.3456c8","x":460.1429443359375,"y":682.8571310043335,"wires":[["8d6a2f85.239ab","93e2b691.2d2f78"],[]]},{"id":"bddb7999.5e39f8","type":"ui_template","z":"3007b84d.585828","group":"55e082a0.9e821c","name":"","order":5,"width":"6","height":"10","format":"<div style=\"width:100%;\">\n <div style=\"display:inline-block; width:25%;\" ng-repeat=\"x in msg.payload track by $index\">\n {{!msg.input.payload.conversion ? \n ($index + msg.input.payload.address) : \n (($index*2 + msg.input.payload.address)+'-'+($index*2 + msg.input.payload.address+1))}} : {{ x }}\n </div>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1485.14306640625,"y":692.8571166992188,"wires":[[]]},{"id":"63a764b7.de8d4c","type":"inject","z":"3007b84d.585828","name":"init","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"x":160.1429443359375,"y":862.8571310043335,"wires":[["f31e0c5a.d1de9"]]},{"id":"f31e0c5a.d1de9","type":"function","z":"3007b84d.585828","name":"init","func":"flow.set(\"FC\", 3);\nflow.set(\"address\", 1);\nflow.set(\"length\", 1);\nflow.set(\"enabled\", false);\nflow.set(\"count\", 0);\nflow.set(\"conversion\", 0);\nflow.set(\"hex\", 0);\nflow.set(\"conversion_float\", 0);","outputs":"0","noerr":0,"x":289.1429443359375,"y":862.8571310043335,"wires":[]},{"id":"ad93667a.a6fa78","type":"inject","z":"3007b84d.585828","name":"init","topic":"","payload":"count","payloadType":"flow","repeat":"0.5","crontab":"","once":false,"onceDelay":"","x":482.1429443359375,"y":623.8571310043335,"wires":[["67a50272.e8e96c"]]},{"id":"67a50272.e8e96c","type":"ui_text","z":"3007b84d.585828","group":"55e082a0.9e821c","order":1,"width":"5","height":"1","name":"read count","label":"Total reads: ","format":"{{msg.payload}}","layout":"row-spread","x":637.6429748535156,"y":623.8571329116821,"wires":[]},{"id":"d19ca237.83a9d","type":"status","z":"3007b84d.585828","name":"","scope":["85dd1b59.3dac48"],"x":113.6429443359375,"y":623.8571310043335,"wires":[["9136d04e.8d1f7"]]},{"id":"9136d04e.8d1f7","type":"ui_text","z":"3007b84d.585828","group":"55e082a0.9e821c","order":2,"width":"5","height":"1","name":"Modbus status","label":"Status:","format":"{{msg.status.text}}","layout":"row-spread","x":294.1429443359375,"y":623.8571310043335,"wires":[]},{"id":"4ab48214.f2ebac","type":"function","z":"3007b84d.585828","name":"16To32Bit","func":"var values32bit = [];\n\nfor(var i=0;i<msg.payload.length;i++){\n var tmp = msg.payload[i].toString(2);\n tmp = tmp.length < 16 ? '0'.repeat(16-tmp.length) + tmp : tmp;\n i++;\n var tmp1 = i < msg.payload.length ? msg.payload[i].toString(2) : '0000000000000000';\n tmp1 = tmp1.length < 16 ? '0'.repeat(16-tmp1.length) + tmp1 : tmp1;\n var value = parseInt(tmp1+tmp,2);\n if(flow.get('hex')) value = '0x'+value.toString(16).toUpperCase();\n \n values32bit.push(value);\n}\n\nmsg.payload = values32bit;\n\nreturn msg;","outputs":1,"noerr":0,"x":885.1429977416992,"y":707.8571300506592,"wires":[["ea3e65dc.00f918"]]},{"id":"93e2b691.2d2f78","type":"switch","z":"3007b84d.585828","name":"","property":"conversion","propertyType":"flow","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":670.6429443359375,"y":675.8571166992188,"wires":[["f93f41eb.2fa72"],["8e82685d.ac14a8","cba46076.4678e"]]},{"id":"526c1517.222e1c","type":"ui_switch","z":"3007b84d.585828","name":"","label":"32 bit","group":"426c6703.2c1038","order":5,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","x":429.6429443359375,"y":1083.8571310043335,"wires":[["91ac90a0.b2fb5"]]},{"id":"91ac90a0.b2fb5","type":"function","z":"3007b84d.585828","name":"save","func":"flow.set(\"conversion\", msg.payload);\nif(!flow.get(\"conversion\") && flow.get(\"conversion_float\"))\n flow.set(\"conversion_float\", 0);","outputs":"0","noerr":0,"x":592.1429443359375,"y":1083.8571310043335,"wires":[]},{"id":"c1dfb404.7cc128","type":"ui_dropdown","z":"3007b84d.585828","name":"","label":"FC","place":"FC","group":"426c6703.2c1038","order":3,"width":0,"height":0,"passthru":false,"options":[{"label":"Read Coil Status FC 1","value":1,"type":"num"},{"label":"Read Holding Register FC 3","value":3,"type":"num"},{"label":"Read Status Register FC 4","value":4,"type":"num"}],"payload":"","topic":"","x":429.1429443359375,"y":1043.8571310043335,"wires":[["f48850f7.e3c05"]]},{"id":"360c92cd.c9302e","type":"inject","z":"3007b84d.585828","name":"","topic":"","payload":"address","payloadType":"flow","repeat":"","crontab":"","once":true,"x":214.1429443359375,"y":955.8571310043335,"wires":[["f947b91c.fa0988"]]},{"id":"db5eca59.3fd018","type":"inject","z":"3007b84d.585828","name":"","topic":"","payload":"length","payloadType":"flow","repeat":"","crontab":"","once":true,"x":213.1429443359375,"y":1000.8571310043335,"wires":[["cc40dff8.48c9e"]]},{"id":"8304bcdd.2a20e","type":"inject","z":"3007b84d.585828","name":"","topic":"","payload":"FC","payloadType":"flow","repeat":"","crontab":"","once":true,"x":202.1429443359375,"y":1043.8571310043335,"wires":[["c1dfb404.7cc128"]]},{"id":"b4eeaa7.1e11658","type":"inject","z":"3007b84d.585828","name":"","topic":"","payload":"conversion","payloadType":"flow","repeat":"0.1","crontab":"","once":true,"x":230.1429443359375,"y":1083.8571310043335,"wires":[["526c1517.222e1c"]]},{"id":"db20baa6.fa3138","type":"modbus-flex-write","z":"3007b84d.585828","name":"write","showStatusActivities":false,"showErrors":false,"server":"5876d9d3.3456c8","x":1173.1429443359375,"y":862.8571310043335,"wires":[[],[]]},{"id":"3568f7ca.d83698","type":"ui_button","z":"3007b84d.585828","name":"write","group":"4a263e90.169ff","order":5,"width":"6","height":"1","passthru":false,"label":"WRITE","color":"","bgcolor":"","icon":"","payload":"true","payloadType":"bool","topic":"","x":868.1429443359375,"y":862.8571310043335,"wires":[["9b8a12eb.e8c74"]]},{"id":"9b8a12eb.e8c74","type":"function","z":"3007b84d.585828","name":"enable","func":"var value = flow.get(\"value\");\n\nif(flow.get(\"conversion_write\"))\n value = parseInt(value, 16);\nelse value = parseInt(value);\n\nmsg.payload = {'value': value, 'fc': flow.get(\"FC_WRITE\"), 'unitid': flow.get(\"unitid\"), 'address': flow.get(\"address_write\") , 'quantity': 1 };\n\nreturn msg;","outputs":1,"noerr":0,"x":1018.1429443359375,"y":862.8571310043335,"wires":[["db20baa6.fa3138"]]},{"id":"cf92cac3.115e98","type":"function","z":"3007b84d.585828","name":"save","func":"flow.set(\"address_write\", msg.payload);","outputs":"0","noerr":0,"x":1287.6429443359375,"y":977.8571310043335,"wires":[]},{"id":"210dfeeb.090bf2","type":"function","z":"3007b84d.585828","name":"save","func":"flow.set(\"FC_WRITE\", msg.payload);","outputs":"0","noerr":0,"x":1288.6429443359375,"y":1018.8571310043335,"wires":[]},{"id":"76ad1330.edf39c","type":"inject","z":"3007b84d.585828","name":"init","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"x":883.6429443359375,"y":923.8571310043335,"wires":[["ce74fd33.da014"]]},{"id":"ce74fd33.da014","type":"function","z":"3007b84d.585828","name":"init","func":"flow.set(\"FC_WRITE\", 6);\nflow.set(\"address_write\", 1);\nflow.set(\"conversion_write\", 0);","outputs":"0","noerr":0,"x":1012.6429443359375,"y":923.8571310043335,"wires":[]},{"id":"690e91a4.45396","type":"ui_switch","z":"3007b84d.585828","name":"","label":"Hex to Int","group":"4a263e90.169ff","order":4,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","x":1133.1429443359375,"y":1058.8571310043335,"wires":[["a028380f.03e638"]]},{"id":"a028380f.03e638","type":"function","z":"3007b84d.585828","name":"save","func":"flow.set(\"conversion_write\", msg.payload);","outputs":"0","noerr":0,"x":1289.6429443359375,"y":1058.8571310043335,"wires":[]},{"id":"6d4a2b49.6c8284","type":"ui_dropdown","z":"3007b84d.585828","name":"","label":"FC","place":"FC","group":"4a263e90.169ff","order":3,"width":"0","height":"0","passthru":false,"options":[{"label":"Force Single Coil FC 5","value":"5","type":"str"},{"label":"Force Single Register FC 6","value":6,"type":"num"}],"payload":"","topic":"","x":1124.6429443359375,"y":1018.8571310043335,"wires":[["210dfeeb.090bf2"]]},{"id":"bef26ae7.614ba8","type":"inject","z":"3007b84d.585828","name":"","topic":"","payload":"address_write","payloadType":"flow","repeat":"","crontab":"","once":true,"x":924.6429443359375,"y":977.8571310043335,"wires":[["c90dfb95.6bdc38"]]},{"id":"730f0b41.fb3724","type":"inject","z":"3007b84d.585828","name":"","topic":"","payload":"FC_WRITE","payloadType":"flow","repeat":"","crontab":"","once":true,"x":915.6429443359375,"y":1018.8571310043335,"wires":[["6d4a2b49.6c8284"]]},{"id":"512a8b3a.5dee64","type":"inject","z":"3007b84d.585828","name":"","topic":"","payload":"conversion_write","payloadType":"flow","repeat":"0.1","crontab":"","once":true,"onceDelay":"","x":933.6429443359375,"y":1058.8571310043335,"wires":[["690e91a4.45396"]]},{"id":"56b9b0e9.e1897","type":"ui_text_input","z":"3007b84d.585828","name":"","label":"Value","group":"4a263e90.169ff","order":2,"width":"3","height":"1","passthru":false,"mode":"text","delay":"100","topic":"","x":1122.1429443359375,"y":1098.8571310043335,"wires":[["6e9920d2.a5989"]]},{"id":"6e9920d2.a5989","type":"function","z":"3007b84d.585828","name":"save","func":"flow.set(\"value\", msg.payload);","outputs":"0","noerr":0,"x":1288.6429443359375,"y":1098.8571310043335,"wires":[]},{"id":"90069d50.bc1c2","type":"comment","z":"3007b84d.585828","name":"READ","info":"","x":74.6429443359375,"y":809.8571310043335,"wires":[]},{"id":"b747e293.f8f91","type":"comment","z":"3007b84d.585828","name":"WRITE","info":"","x":804.1429443359375,"y":810.8571310043335,"wires":[]},{"id":"770472a1.13395c","type":"comment","z":"3007b84d.585828","name":"OUTPUT","info":"","x":86.1429443359375,"y":570.8571310043335,"wires":[]},{"id":"47aa8310.8b3b7c","type":"ui_switch","z":"3007b84d.585828","name":"","label":"Hex Values","group":"426c6703.2c1038","order":7,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","x":435.9085693359375,"y":1130.6071310043335,"wires":[["3b016e18.240e82"]]},{"id":"3b016e18.240e82","type":"function","z":"3007b84d.585828","name":"save","func":"flow.set(\"hex\", msg.payload);\n\nif(flow.get(\"hex\") && flow.get(\"conversion_float\"))\n flow.set(\"conversion_float\", 0);","outputs":"0","noerr":0,"x":589.4085693359375,"y":1130.6071310043335,"wires":[]},{"id":"37aa5a96.cb6946","type":"inject","z":"3007b84d.585828","name":"","topic":"","payload":"hex","payloadType":"flow","repeat":"0.1","crontab":"","once":true,"onceDelay":"","x":200.4085693359375,"y":1130.6071310043335,"wires":[["47aa8310.8b3b7c"]]},{"id":"f93f41eb.2fa72","type":"switch","z":"3007b84d.585828","name":"","property":"hex","propertyType":"flow","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","outputs":2,"x":878.9086074829102,"y":669.6071166992188,"wires":[["9c5eeca5.fac26"],["bddb7999.5e39f8","be6e63a4.9997e"]]},{"id":"9c5eeca5.fac26","type":"function","z":"3007b84d.585828","name":"toHex","func":"for(var i=0;i<msg.payload.length;i++)\n msg.payload[i] = '0x'+msg.payload[i].toString(16).toUpperCase();\n\nreturn msg;","outputs":1,"noerr":0,"x":1032.9085693359375,"y":615.6071166992188,"wires":[["bddb7999.5e39f8","be6e63a4.9997e"]]},{"id":"a05c178a.dab488","type":"inject","z":"3007b84d.585828","name":"","topic":"","payload":"conversion_float","payloadType":"flow","repeat":"0.1","crontab":"","once":true,"onceDelay":"","x":221.1429443359375,"y":1176.8571310043335,"wires":[["697fbeab.91379"]]},{"id":"697fbeab.91379","type":"ui_switch","z":"3007b84d.585828","name":"","label":"Float","group":"426c6703.2c1038","order":6,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","x":410.6429443359375,"y":1176.8571310043335,"wires":[["6eb4434f.c0697c"]]},{"id":"6eb4434f.c0697c","type":"function","z":"3007b84d.585828","name":"save","func":"flow.set(\"conversion_float\", msg.payload);\nif(!flow.get(\"conversion\") && flow.get(\"conversion_float\"))\n flow.set(\"conversion\", 1);\n\nif(flow.get(\"conversion_float\"))\n flow.set(\"hex\", 0);","outputs":"0","noerr":0,"x":587.1429443359375,"y":1176.8571310043335,"wires":[]},{"id":"ea3e65dc.00f918","type":"switch","z":"3007b84d.585828","name":"","property":"conversion_float","propertyType":"flow","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"}],"checkall":"true","outputs":2,"x":1031.1429443359375,"y":737.8571166992188,"wires":[["bddb7999.5e39f8","be6e63a4.9997e"],["e1287907.03a0d8","aca9bf8c.b3ba"]]},{"id":"518d47aa.bcb938","type":"comment","z":"3007b84d.585828","name":"CONNECTION","info":"","x":118.46179962158203,"y":41.56597328186035,"wires":[]},{"id":"d8bd00c6.4441f","type":"ui_text_input","z":"3007b84d.585828","name":"","label":"Address","group":"b079e2a.7753f2","order":3,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":546.4617919921875,"y":131.01041412353516,"wires":[["606bf156.41c3"]]},{"id":"3e658f6f.6cb3c","type":"modbus-flex-connector","z":"3007b84d.585828","name":"connection","maxReconnectsPerMinute":4,"emptyQueue":false,"showStatusActivities":false,"showErrors":false,"server":"5876d9d3.3456c8","x":450.46185302734375,"y":385.01045298576355,"wires":[]},{"id":"f4df0c24.1b02c","type":"ui_text_input","z":"3007b84d.585828","name":"","label":"Port","group":"b079e2a.7753f2","order":4,"width":"3","height":"1","passthru":true,"mode":"text","delay":300,"topic":"","x":536.4791259765625,"y":175.01040649414062,"wires":[["ad832272.c1a76"]]},{"id":"606bf156.41c3","type":"function","z":"3007b84d.585828","name":"save","func":"var options = flow.get(\"TCP_Connection\") || {};\n\noptions.tcpHost = msg.payload;\n\nflow.set(\"TCP_Connection\", options);","outputs":"0","noerr":0,"x":700.017333984375,"y":131.23263549804688,"wires":[]},{"id":"ad832272.c1a76","type":"function","z":"3007b84d.585828","name":"save","func":"var options = flow.get(\"TCP_Connection\") || {};\n\noptions.tcpPort = msg.payload;\n\nflow.set(\"TCP_Connection\", options);","outputs":"0","noerr":0,"x":698.017333984375,"y":175.23263549804688,"wires":[]},{"id":"17332db6.9ffd62","type":"ui_text_input","z":"3007b84d.585828","name":"","label":"Unit ID","group":"b079e2a.7753f2","order":5,"width":"3","height":"1","passthru":true,"mode":"text","delay":300,"topic":"","x":535.4791412353516,"y":225.23263549804688,"wires":[["ed279caf.4274c"]]},{"id":"ed279caf.4274c","type":"function","z":"3007b84d.585828","name":"save","func":"var options = flow.get(\"TCP_Connection\") || {};\n\noptions.unitId = msg.payload;\n\nflow.set(\"TCP_Connection\", options);","outputs":"0","noerr":0,"x":697.0173492431641,"y":225.45486450195312,"wires":[]},{"id":"6fff632c.675e9c","type":"inject","z":"3007b84d.585828","name":"","topic":"","payload":"TCP_Connection","payloadType":"flow","repeat":"","crontab":"","once":true,"x":136,"y":147.23263549804688,"wires":[["387c8f76.0fe67","7246ca2.4831f34","a4883537.fd0a58","df543765.66fc68"]]},{"id":"387c8f76.0fe67","type":"change","z":"3007b84d.585828","name":"set","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.tcpHost","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":385.0173645019531,"y":131.23263549804688,"wires":[["d8bd00c6.4441f"]]},{"id":"7246ca2.4831f34","type":"change","z":"3007b84d.585828","name":"set","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.tcpPort","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":383.0173645019531,"y":175.23263549804688,"wires":[["f4df0c24.1b02c"]]},{"id":"a4883537.fd0a58","type":"change","z":"3007b84d.585828","name":"set","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.unitId","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":380.0173645019531,"y":225.23263549804688,"wires":[["17332db6.9ffd62"]]},{"id":"c23376c3.7cc9d8","type":"ui_button","z":"3007b84d.585828","name":"connectTCP","group":"b079e2a.7753f2","order":6,"width":0,"height":0,"passthru":false,"label":"Connect","color":"","bgcolor":"","icon":"compare_arrows","payload":"TCP_Connection","payloadType":"flow","topic":"","x":109.01741790771484,"y":357.2326593399048,"wires":[["81514fd0.532d5"]]},{"id":"81514fd0.532d5","type":"function","z":"3007b84d.585828","name":"connect","func":"var options = msg.payload;\nvar error = {topic: \"TCP Connect\"};\nvar configs = flow.get('configs_TCP') || [];\n\noptions.connectorType = \"TCP\";\n\nif(!options.name || options.name === \"\"){\n options.name = \"No name\";\n}\n\nif(!options.tcpPort)\n options.tcpPort = 502;\n\nif(!options.tcpHost){\n error.payload = \"TCP Host address not Valid\";\n node.error(\"Error\",error);\n return;\n}\n\nvar index = configs.findIndex(function(conf) {\n return conf.name == options.name;\n});\n\nif(index < 0)\n configs.push(options);\nelse\n configs[index] = options;\n \nflow.set('configs_TCP', configs);\n\nnode.send([msg, {payload:configs, topic:\"init\"}]);","outputs":"2","noerr":0,"x":288.0174217224121,"y":357.23265838623047,"wires":[["3e658f6f.6cb3c","8dee1c7f.d8241"],["518c79c8.bf0d98"]]},{"id":"bac3fbb6.bea3e8","type":"ui_text_input","z":"3007b84d.585828","name":"custom port","label":"or choose a custom Port","group":"4fe0301e.33802","order":4,"width":"6","height":"1","passthru":true,"mode":"text","delay":300,"topic":"","x":1330.03466796875,"y":157.23262786865234,"wires":[["bd0c13b8.18979"]]},{"id":"6d01ef58.de6eb","type":"ui_text_input","z":"3007b84d.585828","name":"","label":"Unit ID","group":"4fe0301e.33802","order":5,"width":"3","height":"1","passthru":true,"mode":"text","delay":300,"topic":"","x":1308.034683227539,"y":200.4548568725586,"wires":[["b9883b89.d7b0f8"]]},{"id":"f0258c4f.dfc12","type":"inject","z":"3007b84d.585828","name":"","topic":"","payload":"SERIAL_Connection","payloadType":"flow","repeat":"","crontab":"","once":true,"x":926.5555419921875,"y":152.4548568725586,"wires":[["32b2795f.f9f746","52822920.d8f8b8","a6aa7b0b.bc7cb8","743b34e2.0a022c","88c6cbfe.471658"]]},{"id":"32b2795f.f9f746","type":"change","z":"3007b84d.585828","name":"set","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.serialPort","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1162.5729064941406,"y":157.4548568725586,"wires":[["bac3fbb6.bea3e8"]]},{"id":"52822920.d8f8b8","type":"change","z":"3007b84d.585828","name":"set","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.unitId","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1160.5729064941406,"y":200.4548568725586,"wires":[["6d01ef58.de6eb"]]},{"id":"7199d023.e1c6d","type":"function","z":"3007b84d.585828","name":"save","func":"var options = flow.get(\"SERIAL_Connection\") || {};\n\nif(msg.payload)\n options.serialPort = msg.payload;\n\nflow.set(\"SERIAL_Connection\", options);","outputs":"0","noerr":0,"x":1479.5728759765625,"y":111.4548568725586,"wires":[]},{"id":"a6aa7b0b.bc7cb8","type":"change","z":"3007b84d.585828","name":"set","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.serialPort","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1164.5729064941406,"y":111.4548568725586,"wires":[["c04c8a2f.3e48d8"]]},{"id":"c04c8a2f.3e48d8","type":"ui_dropdown","z":"3007b84d.585828","name":"port","label":"Port","place":"Choose a serial port","group":"4fe0301e.33802","order":3,"width":"6","height":"1","passthru":true,"options":[{"label":"/dev/ttyUSB0","value":"/dev/ttyUSB0","type":"str"},{"label":"/dev/ttyUSB1","value":"/dev/ttyUSB1","type":"str"},{"label":"/dev/ttyAMA0","value":"/dev/ttyAMA0","type":"str"}],"payload":"","topic":"","x":1311.5729064941406,"y":111.78819942474365,"wires":[["7199d023.e1c6d"]]},{"id":"bd0c13b8.18979","type":"function","z":"3007b84d.585828","name":"save","func":"var options = flow.get(\"SERIAL_Connection\") || {};\n\noptions.serialPort = msg.payload;\n\nflow.set(\"SERIAL_Connection\", options);","outputs":"0","noerr":0,"x":1480.5728759765625,"y":156.78819274902344,"wires":[]},{"id":"b9883b89.d7b0f8","type":"function","z":"3007b84d.585828","name":"save","func":"var options = flow.get(\"SERIAL_Connection\") || {};\n\noptions.unitId = msg.payload;\n\nflow.set(\"SERIAL_Connection\", options);","outputs":"0","noerr":0,"x":1480.5728759765625,"y":199.78819274902344,"wires":[]},{"id":"743b34e2.0a022c","type":"change","z":"3007b84d.585828","name":"set","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.serialBaudrate","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1161.111099243164,"y":245.78817749023438,"wires":[["6a1aeb9f.420e24"]]},{"id":"c95e660a.10c0d8","type":"function","z":"3007b84d.585828","name":"save","func":"var options = flow.get(\"SERIAL_Connection\") || {};\n\noptions.serialBaudrate = msg.payload;\n\nflow.set(\"SERIAL_Connection\", options);","outputs":"0","noerr":0,"x":1481.111068725586,"y":246.12151336669922,"wires":[]},{"id":"6c12cba3.837cc4","type":"ui_button","z":"3007b84d.585828","name":"connectSERIAL","group":"4fe0301e.33802","order":7,"width":0,"height":0,"passthru":false,"label":"Connect","color":"","bgcolor":"","icon":"compare_arrows","payload":"SERIAL_Connection","payloadType":"flow","topic":"","x":120.0173568725586,"y":409.7881774902344,"wires":[["7f6bcf05.18398"]]},{"id":"6a1aeb9f.420e24","type":"ui_dropdown","z":"3007b84d.585828","name":"BaudRate","label":"Baud Rate","place":"Select a Boud Rate","group":"4fe0301e.33802","order":6,"width":0,"height":0,"passthru":true,"options":[{"label":"","value":115200,"type":"num"},{"label":"","value":57600,"type":"num"},{"label":"","value":38400,"type":"num"},{"label":"","value":19200,"type":"num"},{"label":"","value":9600,"type":"num"},{"label":"","value":4800,"type":"num"},{"label":"","value":2400,"type":"num"},{"label":"","value":1200,"type":"num"},{"label":"","value":300,"type":"num"},{"label":"","value":110,"type":"num"},{"label":"","value":75,"type":"num"}],"payload":"","topic":"","x":1315.239501953125,"y":245.78817749023438,"wires":[["c95e660a.10c0d8"]]},{"id":"d52565a6.856798","type":"ui_dropdown","z":"3007b84d.585828","name":"configurations","label":"Configurations","place":"Choose a conf...","group":"b079e2a.7753f2","order":1,"width":0,"height":0,"passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":1119.731704711914,"y":334.5819034576416,"wires":[["692f58b9.918a78"]]},{"id":"60a10bbf.dd1344","type":"inject","z":"3007b84d.585828","name":"","topic":"init","payload":"configs_TCP","payloadType":"flow","repeat":"","crontab":"","once":true,"x":749.0174331665039,"y":385.01042461395264,"wires":[["518c79c8.bf0d98"]]},{"id":"518c79c8.bf0d98","type":"function","z":"3007b84d.585828","name":"options","func":"var options = [];\n\n\n(msg.payload || []).forEach(function(opt) {\n var tmp = {};\n tmp[opt.name] = opt;\n options.push(tmp);\n});\n\nmsg.options = options;\n\nreturn msg;","outputs":1,"noerr":0,"x":935.0173721313477,"y":364.01040267944336,"wires":[["d52565a6.856798"]]},{"id":"fb2f0f94.099bb","type":"ui_text_input","z":"3007b84d.585828","name":"","label":"Name","group":"b079e2a.7753f2","order":2,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":536.017333984375,"y":84.01041412353516,"wires":[["96d82679.5f3268"]]},{"id":"96d82679.5f3268","type":"function","z":"3007b84d.585828","name":"save","func":"var options = flow.get(\"TCP_Connection\") || {};\n\noptions.name = msg.payload;\n\nflow.set(\"TCP_Connection\", options);","outputs":"0","noerr":0,"x":699.5728759765625,"y":84.23263549804688,"wires":[]},{"id":"df543765.66fc68","type":"change","z":"3007b84d.585828","name":"set","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.name","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":384.5729064941406,"y":84.23263549804688,"wires":[["fb2f0f94.099bb"]]},{"id":"c8092503.4218a8","type":"ui_text_input","z":"3007b84d.585828","name":"","label":"Name","group":"4fe0301e.33802","order":2,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":1313.4617919921875,"y":67.01041412353516,"wires":[["be283b53.2c1d18"]]},{"id":"be283b53.2c1d18","type":"function","z":"3007b84d.585828","name":"save","func":"var options = flow.get(\"SERIAL_Connection\") || {};\n\noptions.name = msg.payload;\n\nflow.set(\"SERIAL_Connection\", options);","outputs":"0","noerr":0,"x":1481.017333984375,"y":67.23263549804688,"wires":[]},{"id":"88c6cbfe.471658","type":"change","z":"3007b84d.585828","name":"set","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.name","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1166.0173645019531,"y":67.23263549804688,"wires":[["c8092503.4218a8"]]},{"id":"25b7c027.8c9ff","type":"ui_dropdown","z":"3007b84d.585828","name":"configurations","label":"Configurations","place":"Choose a conf...","group":"4fe0301e.33802","order":1,"width":0,"height":0,"passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":1117.4460067749023,"y":464.5977191925049,"wires":[["7bb61422.078f2c"]]},{"id":"ea6eba8e.556108","type":"inject","z":"3007b84d.585828","name":"","topic":"init","payload":"configs_SERIAL","payloadType":"flow","repeat":"","crontab":"","once":true,"x":744.017391204834,"y":437.4548463821411,"wires":[["174ed9b2.183ab6"]]},{"id":"174ed9b2.183ab6","type":"function","z":"3007b84d.585828","name":"options","func":"var options = [];\n\n(msg.payload || []).forEach(function(opt) {\n var tmp = {};\n tmp[opt.name] = opt;\n options.push(tmp);\n});\n\nmsg.options = options;\n\n\nreturn msg;","outputs":1,"noerr":0,"x":933.0174179077148,"y":416.4548511505127,"wires":[["25b7c027.8c9ff"]]},{"id":"7f6bcf05.18398","type":"function","z":"3007b84d.585828","name":"connect","func":"var options = msg.payload;\nvar error = {topic: \"SERIAL Connect\"};\nvar configs = flow.get('configs_SERIAL') || [];\n\noptions.connectorType = \"SERIAL\";\n\nif(!options.name || options.name === \"\"){\n options.name = \"No name\";\n}\n\nif(!options.serialPort){\n error.payload = \"Serial port not valid\";\n node.error(\"Error\",error);\n return;\n}\n\nif(!options.serialBaudrate){\n error.payload = \"Select a Baud Rate\";\n node.error(\"Error\",error);\n return;\n}\n\nif(!options.unitId){\n error.payload = \"Unit ID not Valid\";\n node.error(\"Error\",error);\n return;\n}\n\nvar index = configs.findIndex(function(conf) {\n return conf.name == options.name;\n});\n\nif(index < 0)\n configs.push(options);\nelse\n configs[index] = options;\n \nflow.set('configs_SERIAL', configs);\n\nnode.send([msg, {payload:configs, topic:\"init\"}]);","outputs":"2","noerr":0,"x":290.0173645019531,"y":409.8992919921875,"wires":[["3e658f6f.6cb3c","fad03663.4dbfe8"],["174ed9b2.183ab6"]]},{"id":"ea932305.81705","type":"change","z":"3007b84d.585828","name":"","rules":[{"t":"set","p":"TCP_Connection","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1458.0652198791504,"y":334.9152021408081,"wires":[["e89e1758.ef8648"]]},{"id":"ae4b6077.b942","type":"change","z":"3007b84d.585828","name":"","rules":[{"t":"set","p":"SERIAL_Connection","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1467.9221725463867,"y":464.4865942001343,"wires":[["fbd5ccd8.b8237"]]},{"id":"eab9475c.d79388","type":"link in","z":"3007b84d.585828","name":"set_tcp","links":["e89e1758.ef8648","8dee1c7f.d8241"],"x":220.46198081970215,"y":84.89933586120605,"wires":[["df543765.66fc68","387c8f76.0fe67","7246ca2.4831f34","a4883537.fd0a58"]]},{"id":"e89e1758.ef8648","type":"link out","z":"3007b84d.585828","name":"set_tcp","links":["eab9475c.d79388"],"x":1620.60462474823,"y":335.47075176239014,"wires":[]},{"id":"7f126cfa.eb6934","type":"link in","z":"3007b84d.585828","name":"set_serial","links":["fbd5ccd8.b8237","fad03663.4dbfe8"],"x":992.4618768692017,"y":66.89929580688477,"wires":[["88c6cbfe.471658","a6aa7b0b.bc7cb8","32b2795f.f9f746","52822920.d8f8b8","743b34e2.0a022c"]]},{"id":"fbd5ccd8.b8237","type":"link out","z":"3007b84d.585828","name":"set_serial","links":["7f126cfa.eb6934"],"x":1630.175989151001,"y":464.0420923233032,"wires":[]},{"id":"370ac568.63436a","type":"inject","z":"3007b84d.585828","name":"init","topic":"","payload":"{\"options\":[]}","payloadType":"json","repeat":"","crontab":"","once":false,"x":728.9999771118164,"y":505.57143783569336,"wires":[["258db9e.0d0fa46","d52565a6.856798","25b7c027.8c9ff"]]},{"id":"258db9e.0d0fa46","type":"function","z":"3007b84d.585828","name":"init confs","func":"flow.set(\"configs_TCP\", null);\nflow.set(\"configs_SERIAL\", null);","outputs":"0","noerr":0,"x":886.7143058776855,"y":506.00001430511475,"wires":[]},{"id":"692f58b9.918a78","type":"switch","z":"3007b84d.585828","name":"check","property":"topic","propertyType":"msg","rules":[{"t":"neq","v":"init","vt":"str"}],"checkall":"true","outputs":1,"x":1277.8570747375488,"y":335.14288997650146,"wires":[["ea932305.81705"]]},{"id":"7bb61422.078f2c","type":"switch","z":"3007b84d.585828","name":"check","property":"topic","propertyType":"msg","rules":[{"t":"neq","v":"init","vt":"str"}],"checkall":"true","outputs":1,"x":1277.0000076293945,"y":464.42857837677,"wires":[["ae4b6077.b942"]]},{"id":"f4c74bcc.c754b8","type":"catch","z":"3007b84d.585828","name":"","scope":["7f6bcf05.18398","81514fd0.532d5"],"x":160.00000762939453,"y":496.42858505249023,"wires":[["469a0794.8fa5e8"]]},{"id":"469a0794.8fa5e8","type":"ui_toast","z":"3007b84d.585828","position":"top right","displayTime":"3","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"Error","name":"error","x":320,"y":496.4285774230957,"wires":[]},{"id":"8dee1c7f.d8241","type":"link out","z":"3007b84d.585828","name":"init_tcp","links":["eab9475c.d79388"],"x":431.42858600616455,"y":330.2857265472412,"wires":[]},{"id":"fad03663.4dbfe8","type":"link out","z":"3007b84d.585828","name":"init_serial","links":["7f126cfa.eb6934"],"x":426.42856788635254,"y":453.1428499221802,"wires":[]},{"id":"f947b91c.fa0988","type":"ui_text_input","z":"3007b84d.585828","name":"","label":"Address","group":"426c6703.2c1038","order":1,"width":"3","height":"1","passthru":true,"mode":"text","delay":300,"topic":"","x":438.2857360839844,"y":955.4285888671875,"wires":[["5250a8de.1acd38"]]},{"id":"c90dfb95.6bdc38","type":"ui_text_input","z":"3007b84d.585828","name":"","label":"Address","group":"4a263e90.169ff","order":1,"width":"2","height":"1","passthru":true,"mode":"text","delay":300,"topic":"","x":1124.2857666015625,"y":977.7142944335938,"wires":[["cf92cac3.115e98"]]},{"id":"cc40dff8.48c9e","type":"ui_text_input","z":"3007b84d.585828","name":"","label":"Length","group":"426c6703.2c1038","order":2,"width":"3","height":"1","passthru":true,"mode":"text","delay":300,"topic":"","x":427.1428527832031,"y":1001.1428833007812,"wires":[["dd349bfe.086ca8"]]},{"id":"ae1af357.01906","type":"inject","z":"3007b84d.585828","name":"","topic":"init","payload":"{\"payload\":null}","payloadType":"json","repeat":"1","crontab":"","once":false,"x":838.5714492797852,"y":307.1428499221802,"wires":[["d52565a6.856798","25b7c027.8c9ff"]]},{"id":"e1287907.03a0d8","type":"toFloat","z":"3007b84d.585828","name":"","toFixed":"4","x":1287.6429443359375,"y":761.8571166992188,"wires":[["bddb7999.5e39f8","be6e63a4.9997e"]]},{"id":"8d6a2f85.239ab","type":"ui_text","z":"3007b84d.585828","group":"55e082a0.9e821c","order":3,"width":"0","height":"0","name":"","label":"Received Data: ","format":"{{msg.payload}}","layout":"row-spread","x":449.00000762939453,"y":768.0000534057617,"wires":[]},{"id":"be6e63a4.9997e","type":"ui_text","z":"3007b84d.585828","group":"55e082a0.9e821c","order":4,"width":0,"height":0,"name":"","label":"Converted Data: ","format":"{{msg.payload}}","layout":"row-spread","x":1401,"y":629,"wires":[]},{"id":"cc26bbfe.79b628","type":"function","z":"3007b84d.585828","name":"16To32Bit_Inverse","func":"var values32bit = [];\n\nfor(var i=0;i<msg.payload.length;i++){\n var tmp = msg.payload[i].toString(2);\n tmp = tmp.length < 16 ? '0'.repeat(16-tmp.length) + tmp : tmp;\n i++;\n var tmp1 = i < msg.payload.length ? msg.payload[i].toString(2) : '0000000000000000';\n tmp1 = tmp1.length < 16 ? '0'.repeat(16-tmp1.length) + tmp1 : tmp1;\n var value = parseInt(tmp+tmp1,2);\n if(flow.get('hex')) value = '0x'+value.toString(16).toUpperCase();\n \n values32bit.push(value);\n}\n\nmsg.payload = values32bit;\n\nreturn msg;","outputs":1,"noerr":0,"x":860.7695465087891,"y":758.0039596557617,"wires":[["ea3e65dc.00f918"]]},{"id":"6c39c83d.761918","type":"ui_switch","z":"3007b84d.585828","name":"","label":"Invert","group":"426c6703.2c1038","order":4,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","x":415.01953887939453,"y":1226.003960609436,"wires":[["67f8390b.1fd7e8"]]},{"id":"8e82685d.ac14a8","type":"switch","z":"3007b84d.585828","name":"Inv","property":"inverse","propertyType":"flow","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":671.0195350646973,"y":738.0040216445923,"wires":[["4ab48214.f2ebac"],["cc26bbfe.79b628"]]},{"id":"67f8390b.1fd7e8","type":"function","z":"3007b84d.585828","name":"save","func":"flow.set(\"inverse\", msg.payload);","outputs":"0","noerr":0,"x":585.0195960998535,"y":1226.0039138793945,"wires":[]},{"id":"d5eb6b2e.d43268","type":"inject","z":"3007b84d.585828","name":"","topic":"","payload":"inverse","payloadType":"flow","repeat":"0.1","crontab":"","once":true,"onceDelay":"","x":206.01953125,"y":1226.0039463043213,"wires":[["6c39c83d.761918"]]},{"id":"cba46076.4678e","type":"function","z":"3007b84d.585828","name":"64Bit_Int","func":"// 13.04.2019 Ben ekledim, kodu asagidan aldim\n// 16to32bit ornegine bakarak 4 registeri birlestirdim 64 Bit integer yaptim\n\nvar values64bit = [];\n\nfor(var i=0;i<msg.payload.length;i++){\n var tmp = msg.payload[i].toString(4);\n tmp = tmp.length < 16 ? '0'.repeat(16-tmp.length) + tmp : tmp;\n i++;\n var tmp1 = i < msg.payload.length ? msg.payload[i].toString(4) : '0000000000000000';\n tmp1 = tmp1.length < 16 ? '0'.repeat(16-tmp1.length) + tmp1 : tmp1;\n i++;\n var tmp2 = i < msg.payload.length ? msg.payload[i].toString(4) : '0000000000000000';\n tmp2 = tmp2.length < 16 ? '0'.repeat(16-tmp2.length) + tmp2 : tmp2;\n i++;\n var tmp3 = i < msg.payload.length ? msg.payload[i].toString(4) : '0000000000000000';\n tmp3 = tmp3.length < 16 ? '0'.repeat(16-tmp3.length) + tmp3 : tmp3;\n \n var value = parseInt(tmp+tmp1+tmp2+tmp3,4); // 64 Bit int olarak birlestiriyor\n\n if(flow.get('hex')) value = '0x'+value.toString(16).toUpperCase();\n \n values64bit.push(value);\n}\n\nmsg.payload = values64bit;\n\nreturn msg;","outputs":1,"noerr":0,"x":653.8867263793945,"y":796.6328649520874,"wires":[["a13ddb7f.448088"]]},{"id":"a13ddb7f.448088","type":"debug","z":"3007b84d.585828","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1029.6445770263672,"y":797.9023342132568,"wires":[]},{"id":"aca9bf8c.b3ba","type":"debug","z":"3007b84d.585828","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1279.6328125,"y":826.8984375,"wires":[]},{"id":"426c6703.2c1038","type":"ui_group","z":"","name":"Read (0 Based)","tab":"1810c2ba.d68d0d","order":3,"disp":true,"width":"6","collapse":false},{"id":"5876d9d3.3456c8","type":"modbus-client","z":"","name":"MODSCAN","clienttype":"serial","bufferCommands":true,"stateLogEnabled":false,"tcpHost":"127.0.0.1","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB0","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectTimeout":"2000"},{"id":"55e082a0.9e821c","type":"ui_group","z":"","name":"Output","tab":"1810c2ba.d68d0d","order":5,"disp":true,"width":"6","collapse":false},{"id":"4a263e90.169ff","type":"ui_group","z":"","name":"Write (0 Based)","tab":"1810c2ba.d68d0d","order":4,"disp":true,"width":"6","collapse":false},{"id":"b079e2a.7753f2","type":"ui_group","z":"","name":"TCP","tab":"1810c2ba.d68d0d","order":2,"disp":true,"width":"6"},{"id":"4fe0301e.33802","type":"ui_group","z":"","name":"Serial","tab":"1810c2ba.d68d0d","order":1,"disp":true,"width":"6"},{"id":"1810c2ba.d68d0d","type":"ui_tab","z":"","name":"Modscan (C.Iskender 26.12.2018)","icon":"dashboard","order":2}]
